Results 1 to 10 of 10
Thread: Test kits
    Mar 2017
    Charleston, sc
    18
    Test kits
    One more question, since finances are tight I need the cheapest test kit that will get the job done for now. In a couple of weeks I can upgrade. What should I be looking for in a basic kit?
    30,954
    Re: Test kits
    Time and again on this forum, we see people waste money on an inadequate kit. The problem seems to be that newbies just don't yet understand the requirements for precision that we need.
    I would rather see you wait a couple of weeks and get the TF-100 or K-2006..........you'll be glad you did.
    Apr 2016
    TX
    51
    Re: Test kits
    I echo Dave's sentiments. Also, keep in mind, the couple of bucks you save on a cheaper kit might end up costing you more in the long run, chemical imbalances needing a lot of potentially expensive chemicals to fix, damage from the result of chemical imbalances, possibly unsanitary conditions (remember, you're putting yourself, family, and friends in your hands - this isn't running water, it needs good quality care to be and stay safe).
    TFTestkits has really done all of the hard work for you. Unfortunately, I had to piecemeal my stuff together and it ended up costing me a lot more because I started out on my own before finding TFP. I'd strongly recommend you invest in one of the bundles - it will be worth it!
    Good luck!
    Take care,
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Re: Test kits
    The one you must have is the FAS/DPD chlorine test to follow the TFP method. You can save a few bucks by getting it with the TF-50, especially if you already have a cheap OTO test kit from Wal Mart. I think that's the only thing different between the TF-50 and the TF-100.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mar 2017
    Charleston, sc
    18
    Re: Test kits
    I will def get the one recommended when we get paid. For now I need something so I don't leave the water with no chemicals for 2 weeks so I don't end up with a swamp. So I got some strips that test free chlorine, total chlorine, ph, alkalinity, hardness and stabilizer
    Mar 2017
    Charleston, sc
    18
    Re: Test kits
    Where can I find info on what I need to add and in what order for a brand new pool with hard water with high iron levels
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Test kits
    Test strips are worthless. (see Dave's comment on people wasting money ) That was money that could be spent on a real test kit.
    IF you are getting a decent test kit in 2 weeks, you COULD add enough CYA to get to 30 (one time) and then add 2 ppm FC each day and test pH with one of those cheap HTH 5 way kits or whatever they are. Again, this is all wasted money on sub-par kits but it could save you from having to dump the water and refill when you do get your test kit.
    Basically treat it as a seasonal or temporary pool as laid out in this article Pool School - Guide for Seasonal/Temporary Pools
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2017
    Charleston, sc
    18
    Re: Test kits
    Mr. Bruce that is very helpful, I'd love to return the strips and use the money towards the good kit. How do I know how much cya to add? Or should I just add trichlor? I tried using the pool math calculator but it was giving me 0 for cya because it had trichlor selected. And I didn't know what to change the trichlor to, I'm not familiar with the other options listed. Also, how do I know how much to add each day to get to 2 ppm like you recommended?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Test kits
    Make sure you enter your pool volume at the top. Then enter your current levels in the left hand Now column (left) and your target in the Target column (right). The calculator will also tell you how much chlorine to add.
    Here is the recommended chemicals article.
    I'd just like to reiterate, this is a limp-along "keep the algae away" method until you get your pool kit.
    e: I just looked at the Pool Calculator and I think I understand your question better. For FC section, just use the top line, ignore the drop down on the second line with Trichlor, Dichlor, etc.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Re: Test kits
    I agree with Mr. Bruce, just make sure you add enough bleach or liquid chlorine so your pool doesn't get any algae in the meantime. Stay away from trichlor or or any granular chlorine. If it'll be a couple of weeks or more until you get the good test kit, you might want to get the basic test kit from Home Depot for $7.99 to at least make sure your ph isn't completely out of whack. I used it for a while until I realized that it doesn't do the required FAS-DPD chlorine test, and that it doesn't have a CYA test, which is probably the most critical, since it is this very test that determines what level to keep you FC (free chlorine) level at.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
