Thread: Chasing pH
    Nov 2016
    Las Vegas NV
    35
    Chasing pH
    After finding this site, took over pool care myself. Changed water 3 weeks ago, and dialed the water chemistry right in using info from this forum and Pool Math.
    One issue...I have to keep adding acid to keep pH down to just 7.5. Have targeted 7.3, but have not gotten there even though seeming to be adding a lot of acid.
    Details:
    Pool unused now. In-ground cement. Covered with blanket. Water temp mid 70's. Filtration run 4hrs/day with waterfall spa overflow. Water very clear, no algae, etc.
    Typical values last 3 weeks: pH=7.5-7.6, Cl=5+, CH=450, TA=110, CYA=50, FC=5, CC=0, TC=5.
    Chlorine has held pretty constant...only 4qts of 8-10% added over last 3 weeks (after the initial dosing)
    CH is high, but that is from the city water source here.
    Have been using KleenStrip muriatic acid. Best estimate from web MSDS is that it is 20% acid.
    Have added 6 qts of acid over last 3 weeks. Additions usually bring pH to about 7.4 (I use Pool Math to target 7.3), but a day or two later, pH is up to 7.5+ again.
    Am I just not adding enough acid? For an unused pool with pretty stable chemistry, does the rate or acid use seem out of line? Is the aeration a contributor to increasing pH issue as some posts indicate?
    As always, thanks much.
    DanL, Las Vegas NV
    IG, 2009, 15kGal, 1.5kGal overflow spa, plaster, Pentair system, 420 cartridge filter, Intelliflow 4-160 main pump, Whisperflow feature pump, Poolvergneugen Pool vacuum, liquid chlorine and sometimes pucks, TF-100 test kit, city water autofill, gas heater, Aquatherm Ecosun solar 480sqft, EZ Touch panel with remote, system: Trouble Free Pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Chasing pH
    I would let your ph sit at 7.8 and lower it to 7.6 when it gets to 8.0. The spa overflow is driving pH up through aeration. If you run it less the pH will go up less. Also, TA at 110 will push PH up. Adding acid to lower PH will slowly lower TA too. Or you can actively lower TA following this, Pool School - Lower Total Alkalinity. TA down between 70-80 will slow your pH rise quite a bit.
    Jun 2015
    Mandeville, LA
    109
    Re: Chasing pH
    Why are you trying to target such a low PH? Follow the advise above.
    Nov 2016
    Las Vegas NV
    35
    Re: Chasing pH
    Quote Originally Posted by WyattEarp View Post
    Hey Wyatt,
    I am exactly trying to follow the advice above. Trying to get TA below 100 and doing that by just what the link explains. Getting to pH 7 - 7.2 is part of the process.
    DanL, Las Vegas NV
    Jun 2015
    Mandeville, LA
    109
    Re: Chasing pH
    Good deal. Once you get that TA down the PH rise should get better
