Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Water not clearing and FC at 0
    Mar 2017
    Wake Forest, NC
    12
    Hi All,
    I had my opened 2 days ago, and utilised a local company to do the equipment side of things. I decided to manage the chemicals and cleaning myself. However, I have hit a snag.
    I have vac'd and brushed the pool both days (the bottom and walls are now clear), and have backwashed on both days. The pool water at this stage is cloudy and remains greenish.
    My chemicals look like this:
    pH: 7.4
    FC: 0
    Alkalinity: 90
    Hardness: 300
    CYA: 25
    I have added 14lbs of shock plus (7 on both days) and have given the right dose of algaecide.
    I cannot get the FC level above 0, and the water isn't changing. Does anyone have any kind advice for me, or am I being impatient?
    Tony
    30,955
    Re: Water not clearing and FC at 0
    Welcome to the forum
    It sounds like you do not have a good understanding of the consumptive nature of chlorine. Chlorine kills algae but in the process chlorine is consumed.
    You need to do a process we call SLAM.
    It is not a one time dose of chlorine but rather repeated doses of chlorine to clear your pool.
    Please read "The "ABC's of Pool Water Chemistry" up in Pool School. Then read the SLAM article in Pool School. Ask lots of questions about the SLAM process and don't try ANY shortcuts.......they most always don't work.
    Mar 2017
    Wake Forest, NC
    12
    Hi duraleigh and thanks for your advice.
    I am actually trying to follow the slam process, as you recommend, but I was concerned with the comment about seeing an improvement each day. Maybe I just need to keep at it and report back in a few days.
    I'll report back.
    Thanks.
    30,955
    To see that progress you must replenish the FC as often as you can. To let the FC go to zero stops the process.
    Donldson's Avatar
    NW Ohio
    3,219
    Wait a minute, is the "Shock Plus" you are adding from Pool Time? What are the active ingredients? You may be hurting your chances of clearing up your pool by using that rather than using liquid chlorine.
    We are missing a lot of information here that we need to help you. How many gallons is your pool and what are you using to test? That is going to help us out quite a bit.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Mar 2017
    Wake Forest, NC
    12
    20k gallon pool and using a TF-100 FAS-DPD test kit. Using Shock MaxBlue from Pool time (63% Sodium Dichloro-s-triazentrione, copper 0.26% and 'other ingredients' 36.69%), 6-in-1 pool shock. Does that help?
    Feb 2015
    Chandler AZ
    1,061
    Personally, I would not be putting anything with copper in my pool. Using a product with copper in it will eventually lead to staining.
    I'd use liquid chlorine - aka bleach - for the SLAM - and for continued chlorination moving forward. The product you are using also adds CYA, in addition to a small amount of copper.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    domct203's Avatar
    Jun 2015
    CT
    3,905
    Quote Originally Posted by TMeister View Post
    Stop using that granular right away, and switch to liquid chlorine, aka bleach.
    With every 1ppm of FC added with dichlor, you also add 0.9ppm of CYA.
    Copper is the last thing you want to add to a pool. Copper does not evaporate, and as it builds up it will stain your pool and turn blonde hair green.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mar 2017
    Wake Forest, NC
    12
    Thanks domct203 and proavia.
    Rushing out now to buy some liquid chlorine!
    The packet of the powder states 'ready to swim in as little as 15 minutes' so I am really disappointed (and cold in my swim shorts waiting for the pool to clear).
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,667
    They've got you on the right path! Anytime a pool is green you've got a nice algae army that your bleach will attack. A lot of bleach will die (get used up) in each attack, and you'll have to retest, up to once per hour at first like it says on SLAM page, to bump the FC back up to Shock level per your CYA. Keep your bleach army at full strength. Only use the bleach during SLAM and hold off on the solid forms of Chlorine because they almost all come with CYA too, which partners up with some of your FC to form your chemical sun umbrella - which you have enough of for the SLAM. You don't want more umbrella, you want more algae fighters. Hope this wasn't too silly and made sense.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    Jan 2012
    'burbs of Augusta, Georgia
    8,586
    Please run an updated CYA test. All that powdered product (ugh!) also raised your CYA level which in turn raises the amount of chlorine you need to kill algae. Check the CYA/Chlorine chart to update how much FC you need to SLAM--> FC/CYA Chart
    (and lets not even think about the copper it added... no bueno!)
    Liquid chlorine (aka bleach) is the ONLY product you need to use to perform a SLAM and then care for your pool after if you don't have a SWG. Stay away from anything solid or granular unless you desire the *extra ingredients* they bring along with them.
    Yippee
    <psssst-algaecide doesn't kill algae....its just a preventative. And one we normally don't recommend anyway>
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mar 2017
    Wake Forest, NC
    12
    BattleOfYakima and YippeeSkippy.
    Thank you both for the advice and explanations - great advice again and I take on board all of it!
    Interesting about the algaecide, I was thinking a little too literally (homicide, genocide, algaecide - I assumed a trend )!
    Just bought 6 gallons of liquid chlorine and sitting by the pool ready to test in an hour or so. Game on!!!
    TMeister
    Feb 2015
    Chandler AZ
    1,061
    Great! Sounds like a plan coming together.
    Post back with your new CYA number too.
    If you run low on liquid chlorine, a quick trip to Walmart or the like for some good old BLEACH is good. It's the same as liquid chlorine, at a slightly lower strength. Just do NOT buy scented or splashless. Bleach is usually listed as 8.25% sodium hypochlorite - Liquid Chlorine usually at 10% or 12.5%. Some Walmarts also have "Pool Essentials Chlorinating Liquid" - which is 10%.
    Since you're sitting around waiting to test again, here's a link to a chlorine calculator to help you see the cost benefit per ounce of the different strengths....
    Chlorine Price Per Ounce Calculator
    Gene
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Welcome Tmeister
    Please add some pool details to your signature line so we can help you better and quicker. Don't know you pool size, but youll likely need to pick up more Jugs of Bleach right away for this SLAM. GLad you joined us, and hope you enjoy the forum.
    Essential Links:
    Mar 2017
    Wake Forest, NC
    12
    Hi All,
    In a break between weeping, I am back to check in. I still have problems.
    I have followed the process for slamming the pool and there has been some partial success. However, my FC is still at 0. My CYA also sits at 0 (despite 4lbs of stabiliser). I have now used about 40 gallons of liquid chlorine.
    The good news is that my water is clear!
    No matter how much chlorine I put in, my values don't change, and I can't shift this CYA level.
    Any thoughts?
    Patrick_B - I'll get my signature line updated very soon!
    30,955
    How are you testing?
    Mar 2017
    Wake Forest, NC
    12
    Hi duraleigh,
    Chlorox test strips + TF-100 FAS-DPD test kit
    ff702's Avatar
    May 2016
    Las Vegas, NV
    87
    I hate to say it, but it seems like there is some testing error here. Unless you have drained your pool and started fresh, there is definitely still CYA in your water.
    How often are you testing you chlorine level? How often are you adding liquid chlorine? I can tell you during the winter with clean water and a healthy chlorine level to start, my pool uses .5-1ppm/day. Where your pool already had algae the chlorine consumption would be far greater if you did not run a SLAM to full completion. Did you pass the 3 criteria for passing SLAM?
    ~42k IG Concrete, Gray Plaster, All Hayward, VS 3hp x2, 400k Heater, Cartridge 150GPM, Color Logic LED Lights, Faux Rock Waterfall/Grotto,
    Mar 2017
    Wake Forest, NC
    12
    I fear you might be right ff702 - testing/tester error. I am using the chemicals in the test kit from last year - do they expire?
    I am testing chlorine 2-3 times per day and adding chlorine twice per day. I haven't passed the 3 tests yet, as I can't get the FC above 0, so no OCLT test pass.
  20. Back To Top    #20
    ff702's Avatar
    May 2016
    Las Vegas, NV
    87
    Have you ever shown any FC on test?
