Results 1 to 10 of 10
Thread: Spa Blower problem
    JBrazzel's Avatar
    Jun 2016
    Gonzales, La
    40
    Spa Blower problem
    When I turn on the spa blower, it comes on and runs for about 5 minutes and then shuts off. I have a silencer 1.5hp with 8 jets controlled by screen logic2. Anybody have a clue what could be causing it to shut off. It will not come back on until the next day and same result.
    26,000 gallon in-ground saltwater gunite with pebble sheen Ocean Blue plaster, Pentair intellitouch automation with screen logic2 interface and , intellibrite 5g LED lighting, (3) variable speed intellifloXF pumps, raised spa with (2) spillovers and swim up bar, pentair clean&clear plus cartridge filter, Mastertemp Heater, Ultratemp heat pump, IC40 SWG, multiple water and fire features, Stone creek pavers Precast Concrete coping. TF-100
    JoyfulNoise's Avatar
    May 2015
    14,094
    Re: Spa Blower problem
    Sounds like the thermal limit switch is kicking in to protect the blower from overheating and burning itself out.
    Any obstructions? Take the blower off the pipe and see if it will run when not trying to push air through the tube. You may have an obstruction in the air line to the spa.
    Matt
    JBrazzel's Avatar
    Jun 2016
    Gonzales, La
    40
    Could my pump speed be causing the problem? When the air blower is powered on in screen logic it automatically increases the rpm on the pump to 3440/min
    May 2015
    14,094
    Spa Blower problem
    Yeah, I sincerely doubt you need to run your pump at full speed unless you're trying to rip the flesh off your body.
    You need to go into the programming and change the speed associated with the AUX relay running your blower to a lower speed. You can't be doing good things to your filter running the pump that hard.
    However, pump speed should not impact the AUX circuit powering the blower without a breaker tripping. I would still test for an obstruction.
    Matt
    JBrazzel's Avatar
    Jun 2016
    Gonzales, La
    40
    Thanks Matt, I am going to play with it tomorrow and see it fixes the problem.
    May 2015
    14,094
    Quote Originally Posted by JBrazzel View Post
    Good luck. Please report back the fix so others can learn from it.
    Matt
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Pump speed doesn't have any effect on the blower motor. All the blower is doing is sucking in air to push down the pipe to add bubbles to the spa. So pump speed doesn't matter.
    Thermal issue, obstruction, or the blower is just old and worn out. Things happen. Remove the blower from the stand pipe and turn it on and see if it runs or not. If it shuts off while not on the pipe, you're looking at a replacement of the unit as it's internal to the blower then. Unless of course a mouse built its home inside the unit.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Bro61021's Avatar
    Nov 2016
    Palm Coast
    14
    I had a similar problem and concluded it was the limit switch preventing the unit from overheating. I drilled small holes in the mounting pipe that the air blows through. I did 1 or 2 holes at a time. Each time I drilled a hole the unit ran longer. I wound up with 5 holes and the unit now keeps running. If you drill too many holes you will loose presure so go slowly. You can always tape the holes shut if you drill to many. This worked for me.
    39'x18' cement pool with 4'x6' Hot Tub. Jandy valves can be set to filter the pool and spa or just circulate the water in the hot tub. Have a 400,000 BTU propane heater for quick heat-up. there is a spillway between the spa and the pool. We live in Florida where the sun is hot and plenty of it. the pool is 9 1/2' deep in the deep end and 4" in the shallow end and holds 29,000 gallons of water. We use chlorine. 1 1/2 HP pump.
    JBrazzel's Avatar
    Jun 2016
    Gonzales, La
    40
    Easy Fix.....called the air supply tech support this morning, the pump speed at 3400rpm was creating to much pressure for the air blower. 2700rpm and it works fine now.
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    You learn something new everyday.
    Paul
