Thread: First time doing DIY liner replacement
    Mar 2017
    Shalimar
    2
    Planning a liner replacement in Fall for my 18x24 oval inground pool in Shalimar, FL; within 2 miles of water on Gulf Coast. Pool has dish bottom, with lowest point at 6'. My pool is on slightly elevated deck, a little less than 2 feet above the level of my lawn. I dug down into my yard to check ground water table and encountered water at about 3 feet. So, I believe Ground water level is currently 12-18 inches above lowest point. I am unable to locate any well points from previous liner replacements, therefore I am researching DIY well points in order to temporarily lower ground water table and eliminate possibility of damage to pool bottom during liner replacement (cement/vermiculite I think).
    Based on what I've read so far, I think I need PVC, a 6' hole in the yard just off the pool deck, gravel, and a pump.
    Am I missing anything here?
    Best pump for this very shallow well? (I have a gas powered sump pump on hand that may work, I don't have a submersible pump on hand).
    Appreciate any advice.
    dave
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: First time doing DIY liner replacement
    Welcome to TFP Dave,
    There ought to be some DIY liner folks along to help before long. Enjoy your time on TFP!
    Essential Links:
    Mar 2017
    Shalimar
    2
    Thanks Patrick, I wasn't sure that I had posted this correctly as new thread, but will look forward to what folks may contribute.
    dave
