Thread: HeatMaster 400 stack flue sensor replacement
    Hi folks. the heatmaster 400 threw an e05 error. heater turns on for 15 seconds and then turns off. all research shows that it is a bad sensor.
    The question: Is there a difference in longevity in the Pentair 42002-0024S vs the non Pentair stack flue sensors? Pentair brand is upwards of $70+, non Pentair replacements are $22 on Amazon. Is there a difference? Thanks.
    Regards,
    Peter
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Re: HeatMaster 400 stack flue sensor replacement
    You get what you pay for in most cases. Although it might be more expensive, the real deal Pentair part should be the way to go. I have no clue who makes the knock offs or if they are reliable. I guess the worst that could happen is the knock off fails and the heater melts down.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
