Results 1 to 8 of 8
Thread: CYA very high?
    derek533's Avatar
    Mar 2017
    Edmond, OK
    15
    CYA very high?
    Hi all, just opened pool to a green swamp. Have gotten water clear through use of chlorine tabs and shock (HTH 3 in 1). Last time I tested was at the pool store (I know, before I stumbled upon you guys), and it was I think 90 which was last week. We just had 3" of rain last night too and I haven't drained any off.
    Here are my numbers today with a clear pool with just dead algae and dirt on the bottom. Zero green.
    FC 6.0
    CC 0.6
    PH 7.2
    TA 150
    CH 800
    CYA >100
    24,000 Gallon In-Ground Plaster
    Pentair DE 48sf Filter
    Hayward Superpump
    Hayward Shark Robot
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Re: CYA very high?
    Hi,
    Yeah, the CYA is way too high and most likely from use of shock and chlorine tabs over a period of time. When the shock and tabs add chlorine, they also add CYA. CYA doesn't go away on it's own. It just builds and builds with each tab. As the CYA level continues to increase, that means more chlorine needs to be added to be effective at keeping the pool sanitary. After a while, it becomes either impossible or unreasonable to add the amount of chlorine needed to overcome the buffering effects of the CYA.
    Unfortunately, the only way to lower the CYA is to drain water from the pool and refill.
    As for the rest of the test results - yeah, you know what Im gonna say about pool store testing don't ya! ?
    If you intend on getting your CYA under control ASAP, don't worry about the rest of it until you do.
    Divin Dave,
    derek533's Avatar
    Mar 2017
    Edmond, OK
    15
    Re: CYA very high?
    Crud, knew you were going to say that. I'm going to test again tomorrow when we have some sun as it appears that can affect the reading as well.
    Hayward Superpump
    Hayward Shark Robot
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: CYA very high?
    I would do the test again using equal parts pool water and tap water. Then use this water to perform the test again, but double the results. You may actually be well over 100+ on your CYA. That's gonna help you determine how much you need to drain and refill.
    Yip
    Oh yeah... and you need a better test kit than a pool store. Go for the TF-100 from TFTestkits.net Most comprehensive kit and will last all year and maybe into next...
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    derek533's Avatar
    Mar 2017
    Edmond, OK
    15
    Re: CYA very high?
    I've got a Taylor K-2006. That will suffice won't it?
    Hayward Superpump
    Hayward Shark Robot
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: CYA very high?
    It'll take time but you can deal with high CYA with partial draining /filling but have patience! Get rid of the pucks and use bleach only. Might take a year but use the chart to determine FC levels appropriate to your CYA number. It'll be fine, follow the program.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Jan 2012
    8,550
    Re: CYA very high?
    Quote Originally Posted by derek533 View Post
    Oh yes! I thought you were getting the tests done at the pool store. Sorry!
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: CYA very high?
    That's the best! You've entered the "no-fail" zone.
