Results 1 to 19 of 19
Thread: New build in San Diego
    Oct 2016
    San Diego, ca
    5
    First time pool owner and new build. My husband and I have lived in San Diego over 21 years and recently bought a new home on 2 acres but it is about 15 miles inland from the coast and much warmer than living close to the ocean. I have always wanted my own pool since I was a little girl and finally my dream is coming true. We have a pool builder and have signed docs but I have been a lurker here for a while and hoping all of you can review my proposed equipment and design and offer advice or changes if needed.
    We have one son that is in college, so it is just the two of us at home that will use the pool (and 4 dogs but doubt they will swim). We have a limited area to put the pool as their is a slope behind our home and we are not interested in spending all our money on a huge retaining wall. The backyard also has a enormous waterfall koi pond that will right next to the pool so we really just want a plain well built pool. We have decided not to add a spa and will get a unattached one eventually.
    Here is our specs:
    Pool size 18 x 30/ depth 4ft to 7 ft
    Plumbing - 2 Skimmers/ 3 returns/ 2 Drains
    Coping - Poured Cantilever
    1 Pentair Intellibrite5G light
    Pebble Sheen finish
    Pentair Intelliflo 50/160gpm Circ Pump
    Filter: Pentair Clean and Clear 160 gpm
    Pentair Intellichlor Salt Chlorine
    Pentair Intellichem Chemical Controller
    Solar 100% Coverage
    I will come back and post pictures soon.
    Apr 2016
    TX
    51
    Re: New build in San Diego
    Welcome! I, myself, am a lurker here. Lots of experienced people with a lot of insight.
    Your equipment seems good - it really depends on your situation and environment. The pics will help. At first blush, 3 returns seem low for a pool that size. You might also want to add a 2nd pool light, and a light for the spa. You also want a separate spa drain (not sure if you were counting that in your numbers).
    You might reconsider the poured coping, and might look into some stone or tile, something that's somewhat fixable if something should happen. Intellichlor is pretty much a gold standard, though I myself don't have one, I've only heard good things.
    Sounds like you will have a great pool - congratulations on realizing your dream! I'm sure many others will weigh in when they see some pics.
    Good luck!
    Take care,
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    HI!!! You are going to LOVE having your own pool! TRP makes it SO easy to take care of! BUT we need to get it built first! LOL
    Your pump-What model? When I did a search using the words you wrote I did not get one model. It is more generic. Is the pump you are looking at a 2 speed or Variable speed? Since you will not have any extra features you will do just fine with a 2 speed pump. You will run it on low most of the time. High is for the cleaner or to make a lazy river ride like I do in mine!
    Mo, they are doing a stand alone spa later.
    I would love to see where you are putting the pool. If you lay out a brightly color rope or such so we can see the outline of the pool that is also helpful!
    I love the look of the poured coping. So clean and smooth looking.
    I can't wait to see pics. PLEASE include the koi pond!!!
    Kim
    Oct 2016
    San Diego, ca
    5
    Here are two pics - hopefully I did it correctly and you can see the drawings.
    Oct 2016
    San Diego, ca
    5
    The picture shows a raised edge but we decided to keep it flat. Also the deep end of the pool will be wider than shown in the drawing.
    Apr 2016
    TX
    51
    That is an awesome rendering!
    Jun 2016
    FL
    901
    Fun pond! Anyway to really incorporate the pool/pond?
    Only thought on equipment is maybe go larger on the filter? Most here suggest going bigger for less frequent cleaning. It's really a nominal upcharge, a couple hundred at most.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
    Feb 2017
    Las Vegas
    885
    Pics of the current backyard where the pool will be.... we would love to see
    Jul 2012
    Tallahassee, FL
    33,917
    Quote Originally Posted by Big Will View Post
    AND the pond!!!!!!! lot of pics of the fishy!! please!
    Kim
    Oct 2016
    San Diego, ca
    5
    Here's a couple pics - the pond is extremely murky right now because we had someone out to vacuum some of the silt and mud out this weekend so it really stirred everything up. We also met our new neighbors that live behind us and the husband is a landscape contractor. He is going to dig into the hillside and carve out additional flat area for us. He will also place some large boulders and put in a drain to prevent any dirt or mud coming down the hill. It is going to set our start date back a little as he can't start for 2 weeks but "patience is a virtue" I've heard.
    Feb 2017
    Las Vegas
    885
    Absolutely love your pond! Thanks for posting pics it really gives us a visual, have you thought about rotating the top portion of your pool 45 degrees to the left? Only reason I mention this is to give you more of a true walk way between the pool and pond. I know how fresh water fish can be temperamental at times so the last thing you want is pool water splashing in with pond water .
    Your project is going to be awesome and I look forward to seeing your build
    Jul 2012
    Tallahassee, FL
    33,917
    That is so pretty even with the murky water! Do you have any "show off" pictures of the pond?
    Good catch Will! We all KNOW someone is going to SPLASH and pool water might end up in the fish pond.
    Neat about the neighbor. Is he licensed and insured? I would make sure so him being nice does not come back to bite you. I try my best to not mix business with family, friends, or neighbors. You never know when things might go south and you have to live next door to them Not trying to rain on your parade but it is something to think about.
    Kim
    Jun 2016
    FL
    901
    Could you have a pool waterfall plumbed from the back of the pond spilling into the pool? Sort of like side by side pond and pool waterfalls? It would be so unique to tie them together and it would really catch guests eyes. Of course like others said there would need to be enough of a buffer between them to reduce chance of mixing, I just feel the pond is begging to be part of the pool somehow.
    Sep 2013
    Nashville, TN
    405
    Looks like a really cool project.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Oct 2016
    San Diego, ca
    5
    So we ran into a snag on moving forward when our PB tried getting permits. I guess 3 years ago the former owners did some excavating and built a horse arena and a couple pipe stalls in the front of the property which is where the septic is located. A inspector drove by and asked what they were doing and if they had permits. They said they were not doing anything to the septic. The city contacted them again and asked to come back and do a formal inspection. By this time the owners had covered everything up with dirt and never responded to the requests so a "no issue of any permits" was placed on our address. We now have to hire an engineer to come out and use cameras to verify that nothing was changed on the septic. Soooo Thursday they are coming - I will be back to report the news - hopefully it's good. ��
    Sep 2013
    Nashville, TN
    405
    How frustrating, hopefully it goes smoothly
    Jul 2012
    Tallahassee, FL
    33,917
    How did that not get found before closing?? This is a real question. Who would do the work that finds that kind of info out?
    Upsetting for sure�� Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    That's new for me.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    JB2's Avatar
    Aug 2016
    Hudsonville, MI
    12
    Quote Originally Posted by grumpiebk View Post
    I second the bigger filter.
    The rendering looks great! Going to be a fun summer!
    13.5K, IG 16x36 Wellspring Fiberglass, IntelliFlo VS Pump, Clean and Clear Plus 420 Cartridge, Mastertemp 250,000 BTU Heater, EasyTouch 8 w/ IC40 SWG
