Results 1 to 12 of 12
Thread: What pool salt should I buy?
    Aug 2016
    Broken Arrow, Ok
    2
    Does it matter where I buy my pool salt? The salt at Sam's is more than half the price as that sold in the pool supply stores. The pool supply store said that their salt is 99.9% pure and Sam's is only 99% pure. Help! THank you
    May 2011
    lebanon tn
    370
    Re: What pool salt should I buy?
    99% is fine as long as no iron reducer or such added. I use water softener salt from Home Depot. What ever is cheapest pure salt you can find. Doesn't have to be pool salt, just pure salt
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,126
    I use this. Lots of us here do.
    Diamond Crystal 40 Lbs Water Softener Salt Crystals (100012411) - Water Softener Salt - Ace Hardware
    But if Sams has 99% pure pool salt for less money, then that salt will be just fine.
    Quote Originally Posted by barber View Post
    Divin Dave,
    Akathisia's Avatar
    Jul 2015
    Davis, CA
    130
    I second the Diamond Crystal water softener salt which I learned about on TFP after previously only using "pool salt". Cheaper and worked fine.
    23k gal IG, plaster; IntelliPro 4 x 160 Variable Speed; STA-RITE S7M120 300 sqft cartridge filter; Intellichlor IC40 SWG; Pentair EasyTouch; Maytronics Dolphin Triton Plus robotic cleaner named "Domo" (arigato Mr. Roboto); Hot Spring Vanguard Spa, TF-100 test kit w/SpeedStir, SampleSizer w/Taylor Calibrated Cylinders and FlowVis Flow Meter from TFTestkits.net. Auto fill and Auto drain. Chlorine / CYA Chart
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Solar softener crystals are great too. Buy the cheapest high purity salt with no additives for cleaning softeners, and you'll be fine. Pool Salt is often sold at the crazy price.
    Essential Links:
    Apr 2016
    Riverview, FL
    351
    Walmart has pool salt on sale for $4.88, it's same as what Sam's Club sells. I used this same salt last year for my pool start-up after build, it dissolved quickly and had no residual residue.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Quote Originally Posted by Divin Dave View Post
    FYI my Walmart has this salt for $2.50/bag!!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Update- at checkout, it rang up $1.00/bag! I got 160 lbs of salt for $4.00 + tax!
    I'm going to go back and get several more.
    Denise-TFP Guide
    Jun 2017
    Sachse, TX
    526
    Quote Originally Posted by Nursenini View Post
    Living right!
    What brand is it? I think there have been some negative impacts documented here from the use of Clorox brand salt.
    Blessings, Paul
    12K, StoneScapes Midnight Blue Mini Pebble w/abalone (July 2017 - executed bi-carb startup Refurb - Sachse, Tx), 3 shear descents on raised Austin stone beam, 2 sprayers, 2 skimmers, 4 returns, 2HP pump, STA-Rite S7M120 cartridge filter, 3/4HP Pump for Polaris 280, Circupool RJ 45+, TF-2006, K-1766, & SpeedStir
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    This one!!
    Denise-TFP Guide
    ctrav's Avatar
    Apr 2017
    Northlake TX
    2,239
    Just out of curiosity why would you need so much salt on hand? I was told that I would only need about 2 bags a year...was I misinformed? If so I'm headed to Wally World! Thanks
    Cliff, IG, 22K gal, Pentair WF 2HP 2 Speed Pump, Pentair FNS Plus 60 DE Filter, Hayward PL Plus Pool Management, SWG T Cell-15, 2 LED Hayward Color Logic 4.0 Lights, Water Features, Diamond Brite Black Onyx pool finish, TF-100 Test Kit, PoolMath App, Dolphin S200 Robot (Phin). Northlake, TX New Pool Build
    I support TFP Forums ♥ Has the info saved you $? You can support too!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Quote Originally Posted by ctrav View Post
    We have had so much rain that I have let a bunch of water out of the pool multiple times this year. I have used 4 or 5 bags this year and we haven't hit fall yet. I have room to store it and keep it dry, so I'd rather have several extra at $1 each than have to go out and get it further down the road at $4-5 each.
    Denise-TFP Guide
