Thread: Solar Pool Heater Cover question
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    ok so, my solar cover is supposed to be here on Friday. My question is, do i need to cut out the cover for my deck ladder? or do i just let it lay against it?
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Solar Pool Heater Cover question
    I don't notch mine for my steps just tuck it in the best I can. Makes it easier for me to roll it off that way with the cover roller. Lots of other people will cut it to fit the ladder. Your choice but it is technically better to notch it so it lays on top of as much water as possible. Chances are you probably wont notice the difference.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
