Results 1 to 8 of 8
Thread: Valu Time bleach by Topco
    Jun 2015
    St. Francisville
    78
    Anyone know what % SHC this is? Found on sale for $1 bottle (128 oz). I'm guessing it's 3%. Tried researching online and even called Topco but no help. I have been buying 8.25% (128 oz) at Fred's for $3. They'll run it on sale occasionally for $2.49.
    30k gal, IG, vinyl, Pentair Tagelus TA 60D sand
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Valu Time bleach by Topco
    If it doesn't say, you can presume 3-5% and safely pass it by. 8.25-10% is too easy and cheap to come by to even worry about it.
    Essential Links:
    Jun 2015
    St. Francisville
    78
    I wish I could find 10% around here for a reasonable amount.
    Jun 2015
    St. Francisville
    78
    It's 3%
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    If your location is correct, don't you have a couple Walmarts close by? They sell the 10% for around $3.49/gallon
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    And Walmart sells 6% for $1.77
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2016
    Whitesboro, TX
    85
    I'm getting my 10% bleach at Atwood's for $2.50 a gallon when I buy a case of four.
    22' Round x 52" deep Coleman AGP, 12,500 gallons. Filled 5-1-16. XtremePowerUSA 4500 GPH 19" Sand Filter w/1.5 HP Pump. Hayward Dyna-Skim In The Wall Skimmer. Hard Plumbed w/2" PVC. PVC Aerator. Pentair Kreepy Krauly Lil Shark Above Ground Pool Cleaner. Whitesboro, TX (North Texas). Taylor K-2006 Test Kit Comp Chorine FAS-DPD. Use The Pool Math App By Trouble Free Pool For Logging.
    Jun 2015
    St. Francisville
    78
    That's a great deal!
