Thread: Insulated Hot Tub Spa using Pool Equipment?
    Mar 2016
    Toronto
    136
    We're in Toronto and wondered if there was a solution to using the pool heater and pump to drive a hot tub instead of it having it's own pump and electric heater as is typical here?
    Insulated shell so it is efficient in the winter and likely above ground.
    In summer the water would spill to pool. In winter it would be a closed system
    Just a thought that I'm interested in feedback.
    LP Ultimate 40' FG Pool, 18K Gal., TF-100 Test Kit, TriStar VS 900 Omni Pump, GVA-24 Valve Acuators, 525 Sq.Ft Swim Clear Cartridge Filter, H-Series NG 350K BTU Heater, AquaRite Low Salt SWG, 5 x ColourLogic LED Pool Lights & Transformer, AquaVac QC w/ Foam Rollers
    Apr 2016
    TX
    51
    Re: Insulated Hot Tub Spa using Pool Equipment?
    Hi Van,
    Not sure what that's a problem? As long as you have the appropriate valves to isolate your pool, blow out the lines, and close it for the winter, and you keep your SPA above 0C, should work. Keep in mind though, a spa is pretty small, so you will be using a large pump for a small amount of water, which will be very inefficient. You can get a freeze protector for your spa, something like that comes with various controllers, and even cheaper Intermatic timers, which will kick your pool on when the temperature drops below some preset.
    Good luck!
    Take care,
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Mar 2016
    Toronto
    136
    Thanks Mo. thinking this through and I suppose a pool vs pump and a pump(s) to drive jets in a therapeutic type spa are two different beasts... aren't they?
    My thoughts are based around 4 factors:
    - water conservation by having spa spill into pool
    - energy costs (gas vs hydro)
    - speed to temp (big gas heater vs hydro)
    - upfront savings by sharing equipment as opposed to independent systems.
    Possibly over thinking this as always.
