Thread: REplacing pool motor, anything I should know?
    Oct 2010
    michigan
    284
    just bought this, A.O. Smith 1.65 HP Variable Speed Pool Pump Motor Square Flange - ECM16SQU - INYOPools.com
    ao smith 1.65hp variable speed motor square flange. Should pay for itself in about 2-3 years.
    Is there anything I need to know about installing this? seems fairly easy?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    mas985's Avatar
    Pleasanton, CA
    11,983
    Re: REplacing pool motor, anything I should know?
    Do you have a gokit?
    Mark
    Oct 2010
    michigan
    284
    I don't have a gokit, do you recommend replacing all the seals?
    is this brand good enough? and contain everything I need? could not find a gokit brand
    https://www.amazon.com/Sta-Rite-Supe...e+supermax+kit
    mas985's Avatar
    Pleasanton, CA
    11,983
    YES, I would recommend replacing all seals. I am not familiar with that brand but I stay away from Aladdin brand.
    Mark
