Thread: Hayward pool light install
    Dec 2010
    El Dorado Hills, CA
    104
    I have to replace my Hayward 583 astrolite pool light. Do I have to drain the water to below the light to do it? Only reason I ask is they state the need to use 3m potting compound around the ground. Perhaps I don't need to change the ground wire? Is it separate wire from the light wire?
    Thanks in advance!!
    Ed
    27k gallon in ground, Pebble tec
    Spa with sta-rite max E therm
    Salt water generator
    Pentair intelliflo pump
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Hayward pool light install
    I figured it out. Ground is seperate.
