Thread: Raypak Standard vs Hayward Heat Pro heat pumps
    Jun 2013
    SW Ohio
    27
    Hello all,
    We are looking to extend our swim season a bit and it looks like the best option for us is a heat pump.
    I am wanting to get your feedback on these units or others for quality and also customer service.
    I also see at least Raypak requires licensed installers to not void the warranty. Are they sticklers on this point?
    Raypak Standard 133K BTU Digital Heat Pump - 013331 - INYOPools.com
    Hayward Heat Pro Heat Pump 140,000 BTU - HP21404t - INYOPools.com
    TIA,
    Stan
    1994 18X36 IG vinyl, about 24,000 gallons, Hayward sand filter model S244T, 2 speed 1hp pump w/timer, Dolphin Nautilus Plus Robot, in beautiful SW Ohio.
    ps0303's Avatar
    Jul 2011
    FL
    3,919
    Re: Raypak Standard vs Hayward Heat Pro heat pumps
    I believe all of the manufacturers ask that a licensed installer be used for installing the units in order to keep the warranty in place.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2013
    SW Ohio
    27
    I am a licensed plumber. Wonder if that would suffice?
    Jun 2013
    SW Ohio
    27
    Bump for more feedback on these units please! Thanks.
    Jun 2016
    Virginia
    118
    We just installed the raypac 8350 heat pump -- the only difference is that we opted for the model that also has the chiller feature. We absolutely love it. The goal was to extend the season and we were able to heat the pool from 60 degrees to 80 degrees in 72 hours, despite the fact that it was severely overcast with temps of 55 during the day and low 40s at night. We do have an autocover, though, which is closed at night, so that helps minimize heat loss at night and has somewhat of a solar effect in the afternoon sun (when it is out). Our pool is 30,000 gallons. The unit is quieter than I anticipated, as well. When it is on, it is barely more noticeable than the pool's filter pump.
    Regarding installation, our pool builder installed ours, and that was sufficient for the warranty (as they are an authorized installer). If you are a licensed plumber, maybe just check with RayPac about what they might require?
    IG Gunite 20x40 pool with Pebbletec finish (Tahoe blue with luminous glass in mixed jade); Pentair DE Filter and Pump; Intellibrite LED lights; RayPac 8350 Heat and Cool Heat Pump; NPT Arctic Ice glass tile; Coverstar autocover; Cambridge Renaissance Pavers in Onyx Lite; bluestone coping.
    Jun 2013
    SW Ohio
    27
    Thanks for the feedback yankeelawyer!
