Results 1 to 11 of 11
Thread: ORP accuracy/reliability, worth investing or not?
    Aug 2016
    Belgium
    17
    Hello,
    I'm still in the proces of choosing my pool automation, and i would like to automate as much as possible.
    So i was thinking about pentair intellitouch and intellichem (with liquid chlorine dosing not SWG), but i read a lot of complains about ORP sensing (for chlorine regulation), not only from Pentair but other brands alslo, is it worth investing in this? Most stories i have read, they say that after a while struggeling they just disconect the ORP reading and do it manualy.
    So what is your advice?
    Thank you
    Oct 2007
    Valrico, FL
    557
    Re: ORP accuracy/reliability, worth investing or not?
    ORP will work, but you must keep a very low level of CYA. No more than 20 ppm. Above that amount, ORP will not change in a reliable manner with respect to free Cl.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Aug 2016
    Belgium
    17
    thanks for your answer, are there any downsides of keeping low CYA? and how do you achieve it?
    22,703
    The downside of trying to maintain a lower CYA level is that you use a lot more bleach maintaining proper FC. Especially if you live in a sunny climate.
    Even with a lower CYA level you're not guaranteed that ORP will work reliably over time.
    Aug 2016
    Belgium
    17
    Ok, i heard about FC probes, do you know any system that has that?
    22,703
    I've read a little about the amperometric probes, but haven't seen any in service. They're supposed to be compatible with CYA. The downside is that they're pretty expensive.
    I don't know of any pool automation systems that use them. There could be some that I haven't heard of.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    The industrial ones are very finicky on calibration I know that much. I agree with Bama, and I don't think the technology has made it down to pools yet, but I don't keep up with it either.
    Essential Links:
    Oct 2016
    Belgium
    14
    ORP kinda works if :
    - CYA is under 20
    - probes are recalibrated every year
    - probe housing is keept clean (no debris)
    - new probes every 3-5 years
    - with pool closing: dismantled and stored in storage fluid over winter
    40K Liter (=10K5 gallon) - concrete walls - Hayward Superpump 975W (1,3HP) 3fase powered by an external Siemens Micromaster 420 VFD - Pentair Triton TR-60 glass filter - 13,5Kw Ecoheater heatpump - Hayward Aquarite Pro LS SWG with Sense and Dispense (PH and ORP sensors) - Dryden Aqua Static Mixer - Siemens Logo (mini PLC) automatisation
    Aug 2016
    Belgium
    17
    Quote Originally Posted by Ahrand View Post
    - CYA is under 20
    Well that would work for me! Can anyone confirm?
    So Ahrand that your case, you're happy with it, i see you are from Belgium too?
    I would love to have more info about your setup (Logo Siemens), i'm actualy looking to "make" my own automation too.
    Oct 2016
    Belgium
    14
    Quote Originally Posted by jpcolin View Post
    Actually, I switched it off after 3 seasons fighting with it...
    At the top of summer you need more than 20CYA, otherwise the sun will burn more chlorine tegen the swcg can make.
    I trust my Siemens automation more now.
    Are you Dutch speaking ? Send me a private message.
    Mar 2013
    maryland
    139
    I wrote an article in diy pool automation with Pentair. I have been happy with the coordination of their system. ORP probes as you know are an indirect way to monitor FC. These probes are finnicky. I run a very low flow 15 gpm 24/7 and try to keep my pool at a unifor temperature-- all automated. With that I find orp to be consistent. I have not yet seen cost effectve FC probes. Search the forum for DIY pentair Pool automation and you can find the article. hope it helps.
    " A little knowledge is a dangerous thing"
    19,000 gallon sylvan pool, Easytouch 2 4p automation, Screenlogic interface, Intelliflo VF 3050 pump, Intellichem with Intellichlor 40 chlorinator/Muriatic acid, Raypac millivolt natural gas heater.Polaris pool cleaner with booster pump.Coverstar automatic cover hydraulic mechanism with PCS cover. Wet edge Luna quartz finish 2016. Northeast climate.
