Thread: First full TF-100 tests of the season.
    Killer95Stang's Avatar
    Sunny SoCal
    695
    Received my discounted box of reagents for my TF-100 test kit a couple weeks ago and finally had the time go through a full set of tests. Throughout the winter, I still have my pool open, but I don't bother doing any other tests than OTO FC, PH and DPD CL test. Pool pretty much takes care of itself during the winter, with very minimal doses of Acid and a few laps a week with the Doheny Discovery.
    20,000 gallon pool, Salt Water, Pebble finish plaster. Water is rock hard around here, so high CH is just something I deal with. Water itself is crystal clear and I've never had a hint of algae since the pool was built in 2013. Thankfully, I found TFP before the build process started, so I've never been pool stored and had to battle with off the charts CYA. I've never slammed, "shocked" or even drained an ounce of water from the pool. Besides the extra maintenance of the landscaping around the pool (gardener doesn't go up by the pool), it has been a pleasant experience and very therapeutic to keep the pool up to TFP standards.
    So as of today.
    CL = 5.5 Seems a little high due to drop in CYA
    CC = 0.5
    OTO CL = 5
    PH = 7.5
    TA = 50 Low as a byproduct of managing high CH
    CYA = 40 Had an unusual amount of rain in CA, will get it to 80
    Borate = 40 Will bring it back up to 50
    CH = 780 Will just deal with it
    Salt = 2600 Drop tested Will bring it up to 3000, Intellichlor registers it at 2950.
    Thanks again TFP!!
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jan 2012
    'burbs of Augusta, Georgia
    8,556
    Re: First full TF-100 tests of the season.
    Looks good to me!
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    30,941
    I remember when you first joined the forum.......your pool numbers look terrific....good work!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Nice job on the pool!
    And thanks for getting us all hooked up with the Doheny Discovery Robot! I love mine!
