Thread: Pool light gaskets - Wade Designs?
    Sep 2016
    Bloomington, IN
    19
    Lightbulb Pool light gaskets - Wade Designs?
    Hello all,
    Our pool lights have not worked for quite a few years and this season's project is to see if I can get them going properly. They are connected to a GFI that cuts out when you turn the lights on. I thought an easy and cheap stab at a repair was to replace the gaskets - from 1991 - but am having trouble finding them. There is no manufacturer's information on the "cans" themselves but the lens says "Wade Designs". These are small lights mounted in niches in our fiberglass pool.
    I welcome your thoughts!
    Glenn Anderson
    8' x 4.5' x 75' fiberglass in-ground, indoor pool (installed 1991) with Coverstar automatic cover
    Hayward 250 heater, sand filter
    Hayward .75 HP pump
    Typically use liquid chlorine for sanitizing, Taylor k-2006 test kit
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool light gaskets - Wade Designs?
    Can you post some pictures? both with the lights installed and out on the deck. And one of your GFCI
