Thread: Should I be concerned about what just happened?
    Sep 2016
    ND
    125
    We've had like 2 days that hit around 50 degrees now, and one minute, everything looked good. A few minutes later, I glanced outside, and saw huge bulges in the cover (which I assume is ice moving). I went back on the cameras to see how quickly this happened. Looks like it took about 10 seconds or less.
    Don't mind the mess please, I have lots of work to do this spring.
    10 seconds later....:
    Here's a shot from ground level:
    Is this normal, as things warm up, to see the ice shift like that? For obvious reasons, I can't open the cover to check on things (yet).
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,325
    Re: Should I be concerned about what just happened?
    dw,
    What is this thing you call "ice"????
    I have no idea if normal or not, just wanted to give you a poke..
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,015
    Think about the ice caps! You just had a "calving"! Kind of neat you saw it!
    Kim
    Sep 2016
    ND
    125
    Quote Originally Posted by Jimrahbe View Post
    dw,
    Haha! The good news is that the ice is retreating finally, so it's about time to fire everything up and see if it really works. I took off a skimmer cover on Sunday, and the water in the skimmer was all still in its solid state. I'm guessing that the charcoal pool cover helps some with absorbing the sun and speeding things along, but we have at least another week of ice I would guess.
