Thread: Clogged Polaris line
    Mar 2017
    Dallas/Tx
    1
    Question Clogged Polaris line
    30,000 gallon pool
    i have a 360 Polaris and I have a 60 in pentair filter no booster pump with a simple push pull valve and a small pump motor.
    I just did a filter clean. And it was working before I did he filter clean and now it's not.......
    what happened and how can I get the Polaris line to start pushing water out again?
    Apr 2016
    TX
    51
    Re: Clogged Polaris line
    You might check the strainer at the wall outlet for your booster pump. Hopefully, that's what's clogged. As a general rule, when doing anything to your pool other than normal operation, you should unplug your cleaner and shut off any service valves. Those things can be very delicate, very finicky, and unfortunately very expensive.
    Good luck!
    Take care,
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
