Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Extending Wifi to the Pool Area
    Jan 2017
    Texas Hill Country
    139
    Apologies if this has been discussed. I searched and only saw threads on outdoor speakers/stereos. We have Sonos and are thrilled with it so this is a question about wfi extenders & options only.
    Currently our in-house wifi is very spotty more than 20' from the house. Our walls are concrete and rebar reinforced. Love it but things like this and hanging frames become a bit more complicated than good ole stick-built walls (2x4's, etc.).
    I'm not incompetent tech wise but researching the various products and their capabilities/limitations is confusing. The pool & pergola are about 60' from the house. We currently have to walk in range in order to skip songs and whatnot.
    POE looks interesting but I don't know if the pergola addition will accommodate. It is wired into the house's main electrical panel.
    Any guidance is welcome!
    TIA
    25k IG / Plaster / Built Jul'16 / Spa with Spillway into Pool / Originally filled with trucked in city water, maintaining level with rain water / Polaris 280 Sweep / Jandy Pro Series EPump a& CV 580 Cartridge Filter / Aquacal Heat Pump / AquaLink Control Panel w/PDA / TF-100 Test Kit / 2 Yellow Labs swimmin' all the time
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Extending Wifi to the Pool Area
    How about just a wifi repeater plugged in and sitting on a window sill inside?
    Azmp1's Avatar
    Jul 2012
    Maryland
    295
    60' is pushing it with conventional repeaters, unless you're ready to throw at is some $$$ with pro stuff.
    I should really consider running an Ethernet line to your pergola and setting up an access point there.
    I'm at the similar situation with our new house we're starting the pool build there, I will be running the cat6 line to the pool house.
    32000gl freeform gunite/diamondbrite perl pool || Jandy Sheer Descents || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS6 w/Aqualink touch || Jandy iAqualink2.0 || Pentair Intellibright LEDs || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 140k BTU heat pump
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    It's overkill for you application, but the Hawking 5dbi Omni will completely cover you. Affix to home, power and you'll be shuffling between Willie Nelson and Boy George in no time. LINK: https://smile.amazon.com/dp/B00S6DB4..._t2_B003O7MY1E
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    KenFirch's Avatar
    Aug 2016
    Sacramento CA
    16
    You could get one those WiFi extenders that use your existing electrical outlet wiring, such as this one: https://www.amazon.com/NETGEAR-Power.../dp/B01929V7ZG.
    I've never used one personally, but I think it would be an easy solution, plus you could add more for those dead spots elsewhere.
    25,000 gal IG rectangular, quartz, re-plastered 7/2016
    Pentair equipment: VS pump, 520 filter, IC40 SWG, IntellipH, EastTouch 8, wireless control.
    Polaris P955 robotic cleaner. Taylor K-2006C. Solar Breeze NX.
    Future: Solar panels
    Sep 2016
    ND
    125
    I'm in a similar situation. I'm running a CAT6 cable and putting in a Unifi UAP-AC-M Pro. 600' range should cover our pool area nicely.
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    Nov 2015
    Chicagoland, IL
    209
    I'm tech-dumb, as I leave that to my spouse. We have issues with wifi, too, and our pool is a solid 50 feet from the house. My husband installed a powerline adapter on the outside of the house in a weather protected box, and wired an ethernet cable from the inside of the house to the outside. The signal wasn't strong enough when he installed it inside so he devised a way to install on the house- one on the outside of the house, one inside the shop/poolhouse, where he connected an extender to the powerline adapter. With this set up, we have a substantial portion of the yard between/around house, pool, and shop, covered.
    Edit to add: there are lots of things that can change the effectiveness of this set-up - distance, the breaker panel between two different points, using a different pair of outlets, etc.
    27,000 gal. plaster IG with round spa built in 2007. TFT-100 test kit XL w/ Speedstir
    Jandy CL580 cartridge filter. Jandy 1.0 hp filter pump, 1.5 hp booster/spa? pump.
    Aqualink RS One Touch controls. Paramount PC2000 In-floor cleaning system (1.0 hp pump?). Jandy LX pool heater, apparently broken.
    Missing so much gear due to previous foreclosure, it's sad.
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    221
    Are you already running the Sonos boost?
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
    Jan 2017
    Texas Hill Country
    139
    Quote Originally Posted by Uncle Salty View Post
    Uncle?? lol
    Yes, have a boost hooked up.
    This looks really interesting, need to read up more- https://smile.amazon.com/dp/B00S6DB4..._t2_B003O7MY1E
    We have a couple of the plug in wifi extenders inside the house. They're helpful but don't penetrate outside much. Haven't seen any exterior rated.
    A repeater on a window sill might work but Mrs Salty won't go for the aesthetics.
    Hard wiring just won't happen. With the way the house is built there's no way to get through the walls and this side of the house doesn't have attic space to go through a soffit.
    Thanks for everyone's replies so far. Keep em coming!
    Feb 2017
    South Carolina
    221
    Quote Originally Posted by salty87 View Post
    Uncle?? lol
    Uncle Salty is in reference to a Aerosmith song from around 1975. Just curious what platform are you running your Sonos on, Spotify, Tidal or something else? I just picked up a Sonos system and will be putting it out in my pool house with hard wired Klipsich and a couple of Play 3 speakers, now you got me worried about my range as I haven't tried it out there yet as it's still under renovation. I'll be checking back to see what you end up doing.
    Salty
    Jan 2017
    Texas Hill Country
    139
    My pergola speakers are wired to a Connect:Amp which is located in an outdoor closet near the house. Speaker wires were pre-run from the closet to the pergola during pool construction. The Connect:Amp is plugged into a POE extender that doesn't transmit wirelessly. It does a great job for the Connect:Amp but doesn't do anything for wireless devices. It was pretty cheap, I can look up the info if you'd like.
    The Sonos system runs off our library of music on a network storage device. With our spotty wifi Sonos didn't work well before adding the storage device. We run Apple products though.
    *I've read on Sonos' site that Android devices mesh better with the Sonos network. The Sonos system/speakers communicate over their own broadband for best performance. Each speaker is a repeater. The more you have the better it all works.
    *Disclaimer- this is from my understanding from researching last year when we were starting to set up Sonos and added the network storage device. We live out in the boonies so we don't stream anything. Our provider is rather tight with the data limits.
    Edit- The Salty reference was in regard to both our handles as in long lost uncle, lol.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,326
    You can run a powerline extender like http://www.bestbuy.com/site/netgear-...?skuId=4760605
    It will work anywhere on the same electrical service, and even at a neighbor's house if you share a transformer. I use one to get wifi in my shop which is over 100ft from the house and has metal walls. Takes about 2 minutes to set up.
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    It's a sunny day outside my window
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Sep 2016
    Isle of Palms/SC
    3
    Anybody familiar with Eero? eero - Finally, WiFi that works
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,837
    Speaking of overkill, my wee geeks like the newer Mesh technologies as opposed to boosting...aka, like this:
    https://smile.amazon.com/Linksys-Tri...ds=Mesh+router
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    I have 2 of these, ubiquiti UAP-AC-LITE, one placed in my office and one placed in the Flamingo Lounge. Internal network speeds are gigabit and range is at least 400 ft although I have not actually measured my signals are very strong.
    Quote Originally Posted by dw886 View Post
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    544
    Quote Originally Posted by Brentr View Post
    Something along these lines is all you need ..... we did a wireless link at work to connect two buildings about 1,500 feet away and separated by a public road. The customer was frugal and wouldn't buy commercial grade gear. We ended up with two cheap DLink directional antennas and it worked like a charm. They had 3 PC's and 3 IP Phones in the outbuilding and i never heard another word after the install and that was 10 years ago. I am sure some sort of omnidirectional unit like the one shown would do the job. The ubiquiti stuff is top notch and may be overkill.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Sep 2016
    ND
    125
    Quote Originally Posted by ship of fools View Post
    If you can figure out how to setup the Ubiquiti Unifi stuff, it's top notch. In addition to the UAP-AC-M Pro that I have that's going to be outside, I have 3 UAP-AC-PRO units in the house with pretty clear hand-off between them using Min RSSI. With my current setup, wireless devices are consistently ~70MB download using the SpeedTest website from anywhere in our house on a 150MB cable connection with about 2 dozen wired / wireless devices on the network. I haven't rebooted any equipment in months...
    Mar 2016
    Gilbert AZ
    45
    The real solution is to Run a POE access point out to the pergola as mentioned, everything else may be easier but will be hit and miss and will likely have severe speed reduction.
    11,507 Gallons | In Ground Pebble Tec | QC XHP In Ground Cleaning System | System 3 MM Sta-Rite Filter | Pentair VS-T 3050 Pump | Pentair Ultra Temp 120 H/C | QuickPure 3 Ozone | K2006 Test Kit
  20. Back To Top    #20
    Feb 2017
    Longview / Texas
    96
    Sounds like JohnT has the simplest solution. Just use powerline networking. I have not had a need to do this yet but I believe the technology has advanced and will work. When others are talking about POE are you talking about Power Over Ethernet? If you are doing power over ethernet then you are already running an ethernet cable so problem solved. I apologize in advance if this is not the POE mentioned.
    24' x 52" 13.5K gal. Doughboy Autumn Breeze AG pool. Pentair CC200 Cartridge Filter. Pentair Dynamo 1HP 2 speed pump. Dolphin E-10 robot. TF-100 Test Kit. Confer CCX-AG with curve add on pool steps. My Pool Build.
