Thread: Multiport Valve?
    Aug 2015
    starkville, ms
    9
    Multiport Valve?
    I took off the Multi Port Valve to change the gasket and wanted your opinion. Is it normal for the top spokes not to match the bottom? This is a picture that I took today.
    Thank you!
    Kathleen
    Apr 2016
    TX
    51
    Re: Multiport Valve?
    Yes, that is normal, it's part of the design that allows the flow direction changes. You might consider replacing your valve. It looks pretty worn, and the replacement parts to get everything refurbished is almost half the cost of a new one.
    Good luck!
    Take care,
    Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
