Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Central Texas Pollen - Update with Storm mess
    Aug 2016
    Round Rock, TX
    94
    Question for those folks out there battling, or recently stopped battling, LIVE OAKS and all their droppings. Be it leaves or the yellow-green fronds (apparently called catkins), the pool's nearby live oak is driving me nuts. OK. The question: I'm getting a ton of these pollen fronds in my pool . . . does anyone with this same issue see a higher chlorine demand due to these things?
    So, pool was built and first filled this past November. We've had plenty of sunny days, and sure the water was a bit cooler and the sun's angle is different, but man, the demand spike seems awfully sudden. The sudden spike coincides with the constant dropping of these pollen fronds into our pool. Anyone else?
    We are skimming a lot more, brushing more, using the fine filter on the Doheny's Discovery and cleaning it out daily, and keeping an eye on the tree-spooge culprit praying for it to just drop everything and get it over with. And, yes, when it is over, I'll have the answer to my question, I suppose. Just looking for y'alls feedback.
    Thanks!
    Chris & Lea Stoddard
    20k gal, IG shotcrete/pebble pool/spa combo
    Filled 11/19/2016
    All Jandy: DEV 60, PS Stealth 2 hp 2 spd, LXi (gas) heater, PDA-PS8
    Stenner 45MPHP22 for chlorination
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Central Texas Live Oak Pollen
    Pollen is organic and will consume FC. Run your FC on the high side of the range for your CYA. Just UN-gooed my pool cleaner after having just done it yesterday. After it coats the bag all it can it just balls up on there then. I feel your pain.
    Oct 2015
    austin/texas
    29
    I live in Austin and the pool is surrounded by live oak. I have had the pump running higher for longer just to keep the skimming action going. Have had to run the robot every day to get the stuff falling to the bottom. Have had to manually skim with net 2 or 3 times daily just to keep up.
    I have noticed my FC has been dropping quicker these last two weeks. I attributed it to the water warming up but you may be right, the oak leaves and "katkins" may be eating it up quicker.
    Apr 2010
    East Texas
    10,152
    I'll take dealing with leaves over pollen any day of the week.
    Mar 2017
    SE. TX
    52
    We live in SE Texas and deal with pine trees. I feel your pain.
    Jan 2017
    Texas Hill Country
    139
    Seems like the leaves were worse this spring but also this is first year with a pool so maybe it just seems worse. It's been really windy, too, so that's not helping. At least with the katkins out the leaves are done. Now if all the leaves caught in the grass would stop blowing into the water...
    FC is taking some more attention in my pool, too. Running the filter/vac more as well. I've been adding chlorine at night, not sure if that makes any difference?
    25k IG / Plaster / Built Jul'16 / Spa with Spillway into Pool / Originally filled with trucked in city water, maintaining level with rain water / Polaris 280 Sweep / Jandy Pro Series EPump a& CV 580 Cartridge Filter / Aquacal Heat Pump / AquaLink Control Panel w/PDA / TF-100 Test Kit / 2 Yellow Labs swimmin' all the time
    YetiAsr's Avatar
    Dec 2016
    Pflugerville,Tx
    70
    I'm fighting the same problem with leaves and katkins Salty, I'm running my cleaner daily and cleaning the skimmers at least twice daily and manually skimming daily. I haven't seen a huge spike in FC usage though, but I am super diligent on keeping everything out of the pool. Don't forget we have been really sunny and on the warmer side for this time of year lately.
    31x22 FF IG, 16k gallon , 3.5-5.5-4.5, Hayward 425 cartridge, Tristar variable speed, Aqua Rite AQ15 SWG, HPC 4 wireless controller, LED, Texas Grey pebble finish, Taylor K 2006 and 1766,speedstir ,New build in central Texas....
    Aug 2016
    Round Rock, TX
    94
    Sorry to all those in Central TX. I prayed that the tree dropping all the pollen in my pool would "just get it over with." It really tried. The storm last night made a disaster out of my deck and pool. It tinted the water green there was so much pollen in it. Even though I'm 99.9% sure it isn't algae (water was crystal, and properly balanced at bedtime), I'm going to be diligent. What a mess!
    Anyone else have pollen / last night's storm stories to share? Buddy says it's the one of the worst he's seen in this 13ish years with a pool in Austin.
    Filled 11/19/2016
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Central Texas Pollen - Update with Storm mess
    We have so much pollen my brown truck turned green.
    Jun 2015
    Georgetown
    23
    I think the worst is finally behind us for the catkins. This morning was the second day in a row for me to not find a significant amount floating in the pool or on the deck. There does still appear to be a small amount in the trees however.
    I recently found this historical pollen chart on weather.com Tree pollen peaked from the 21st to the 27th, which is exactly what I experienced.
    https://weather.com/forecast/allergy/l/78633:4:US
    I live in Central Texas and have a 12,000 gallon, in-ground, plaster pool built 2007. Jandy CL340 cartridge filter, Stealth 2.0 single-speed main pump. Polaris cleaner with booster. Attached heated spa with moss rock spillway to pool. K-2006 Test Kit
    Apr 2010
    East Texas
    10,152
    I think those pollen numbers translate to.......per square inch around here.
    Jan 2017
    Texas Hill Country
    139
    Quote Originally Posted by stodds View Post
    Whoa, that's bad. At least they're mostly on that side? In our pool it's been all over the place. Leaves are much easier/quicker to scoop up than these nasty suckers. Stir the water up and they sink but most float back up after you've moved on to a new area.
    They're still falling out near Dripping Springs.
    Aug 2016
    Round Rock, TX
    94
    Storms this weekend. Looking at the tree right now. Still has plenty to give. Ugh. . .
    Filled 11/19/2016
    Jun 2007
    Houston, Texas
    212
    Texas is horrible this time of year. My wife and daughter both have allergies and the pollen is insane. Look at this video.
    Massive Tree Pollen Explosion Explained - YouTube
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Pollen time means summer time ahead!
    Essential Links:
    DFW, TX
    24,974
    Yes!
    TxCoolGuy's Avatar
    Sep 2016
    North Richland Hills, TX
    34
    We have a live oak that hangs over our pool. Our robot and skimmers kept up with it, sometimes emptying the skimmers two or three times a day.
    The pollen though ..wow ..i'm sort of convinced it turned our water green for a while! doing SLAM process now just in case its algae, but our water went green a week ago ..no sign of algae, just a green tint to the water. pictures in the fighting-algae forum.
    19K gal, IG pebble, 3 HP Intelliflo VS+SVRS, 420 sqft Pentair Cartridge Filter, IC40 SWG, IntelliPH, EasyTouch, Screenlogic2, 48sqft Spa, 400K BTU NG Mastertemp Heater, Legend 1 cleaner, 1 HP Boost Rite cleaner pump, TF100 Test Kit w/stirrer
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Same here - have a Live Oak that actually hangs out over the pool. I had it cut way back this year, mainly because the pool needs more sun and doesn't warm up enough for me (that is a rare one in TX -huh) we barely got up to 86 last summer. I won't get in til 84 or 85 and prefer 88 or so.
    To say the least - the pool takes work from September til early April. Acorns start falling in September and go for a couple of months. I just brush the sunning ledge and the Racer runs about an hour and a half a day and does a great job with the bottom of the pool. Some acorns and leaves continue through winter and then March comes around and the catkins (as I've just learned their name from this thread) and dead leaves are horrible for 3 to 4 weeks. I check the skimmers a couple of times a day and use a net at least once a day to keep them scooped up and out of the pool. It stays pretty clean, but it takes work. My chlorine hasn't been too bad - maybe uses a little more this time of year, but easy to keep up with.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Mar 2016
    Spring, Texas
    50
    I now know why palms and all the tropical plants are so popular around pools - thorns and all! We have a forest of green stuff. And it sure is pretty, but goodness gracious all the stuff it blows and drops. It never ends. I don't know what came before the live oak worms as my son calls them, but I noticed the spa spill over was wasn't flowing much and the filter pump had an air pocket so I pulled out a skimmer basket and it was packed! I would have sworn it was a dead bug colony in there with all the black pieces (looked like big dead ants, but we don't have those kinds of ants here!) One of my kids said it was the same stuff that's all over the trampoline and that it comes from one of the trees. I had no idea! It's been so bad I've had to clean the skimmers almost as much with this stuff as when the leaves fall in the fall! And don't even get me started on my neighbors willow tree. It's 200+ feet from the pool but it is the hands down biggest trash tree. If they disappear to Saudi Arabia again for 10 years that tree won't be there when they come back.
    21000 gal IG Pebble Sheen (Blue Surf), Pentair quad DE filter, Sta Rite Intellipro VS pump; Paramount PCC-2000 inground cleaner; Installed May 2016.
  20. Back To Top    #20
    tcat's Avatar
    May 2012
    Austin, TX
    753
    Just noticed this thread, same problem here in Austin. Hopefully it's about over (don't see much left on the trees other than leaves for next year or sooner). These things turn the pool cloudy to green (not algae), and if I don't backwash at least once a week, the pump flow gets so slow, the heat pump stops, and the stenner pump has a hard time distributing chlorine.
    If I run my Aquabot twice, almost all the stuff on bottom gets picked up. My poolskim bag fills almost daily (I use a 5 gallon paint strainer). The best solution is keep the solar cover on as much as possible, and sweep most of it. Just ordered a Solar Breeze to hopefully help a bit more once the cover is off for the rest of the year.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
