Thread: Pentair IntelliBrite 5G problems
    Nov 2014
    Cd del Carmen, Campeche,Mexico
    12
    Less than 2 years after installing 9 IntelliBrite #601002 5G colour pool lights 2 of them have stopped working. Inspection shows the interior bone dry but transistor C18 burnt/melted, (photos attached) control is through IntelliTouch.
    Pentair will sell a Light Engine Kit for $703 or I can buy a replacement light for only $560, with transport and duties to bring to Mexico the cost will be getting on towards 2 thousand dollars, which probable makes these the worlds most expensive transistors!
    Has anyone else experience with this type of failure and hopefully a less expensive solution??
    42K Poured Concrete, Quartz, 4XJetpacks in integrated spa. 3XIntelliflo, Cartridge Filter 420. IntelliTouch+I9+3+iS10 Spa control. Intellichlor IC60, Intellichem+CO2 injection. 9XIntellibrite 5G LEDs HE-150 Heat Pump.
    Re: Pentair IntelliBrite 5G problems
    C19 looks like it has failed as well. Both C18 and C19 were capacitors. I'm betting the fuse at F1 is open as well.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,764
    If you purchased 9 of these lights less than 2 years ago from a brick and mortar pool store, and you have the proof of purchase, they should be under warranty.
    Having said that, you live in Mexico and, to be honest, don't know if that would affect your warranty.
    It shouldn't, but that isn't my call.
    If Pentair turns down your claim, i would push real hard for some sort of warranty.
    Now, if you got these lights through the internet, unfortunately, all bets are off. I believe you only get 90? days. Something like that.
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
