Thread: Pool store, huh?
    Mar 2017
    SE. TX
    52
    Pool store, huh?
    I was looking for R-0871 and a pool store told me that I didn't need it. Just use purified water to get a FC reading above 10 with the R-0001 and 0003. Huh?
    I'll do the TNT version TYVM.
    I have a 24ft round pool. 52in deep. 14k gallons. It has a sand filter. It is a chlorine pool that we got March, 2016. Above ground!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,334
    Re: Pool store, huh?
    In a pinch, you can use bottled water to get a rough idea of a higher FC level. Just dilute your pool water with 3 parts purified water and test the mixture. Multiply the reading by 4. Accuracy suffers unless you measure very well or use a scale to create your mixture.
    Mar 2017
    SE. TX
    52
    Ok, thanks!
