Results 1 to 8 of 8
Thread: Help finding hose
    Mar 2016
    Easley, SC
    407
    Help finding hose
    I am needing a hose to connect to my stenner chlorine tank. It needs to be 1 1/4" ID. Does anyone know where I can find something that size that will work with chlorine? All I could find at HomeDepot is Vinyl. Wasnt sure if that would work.
    18x36 inground / 28k gal / Vinyl liner (replaced in 2018) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump / Stenner pump (85MHP17) w/55 gallon storage tank / Pentair heat pump HP1200 (To be installed) / TF100 Test kit
    Jan 2012
    'burbs of Augusta, Georgia
    8,592
    Re: Help finding hose
    I would suggest calling these two companies- they both have excellent records for finding the unusual pool part-
    sunplay.com
    INYOpools.com
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    30,962
    The vinyl will work but what type of connection do you need to make that requires 1.25" hose??
    Mar 2016
    Easley, SC
    407
    I am installing a 55 gallon drum under my house and will have a fill cap on the outside (kind of like houses with oil tanks under the house). This will just be a convenience thing for me so I do not have to cart the full barrel around the house, I will be able to back up and fill the tank without unloading it. The 1 1/4" is the size of the fill spout and the connection on my drum. I will also be attaching a 1/2" pipe to vent to the exterior in case the barrel ever becomes pressurized although I never see that happening.
    30,962
    I gotcha' now, Thanks. You may get some slow deterioration of that vinyl (brittleness) but you'll be able to see it slowly happening and can replace it if it does. There4 are some high grade hoses you can get but I wouldn't pay for them.
    Mar 2016
    Easley, SC
    407
    I did find some Spa hose thats 1 1/4" ID. It was at HomeDepot but it didnt say what it was made of. It's the white pipe. I was twice the price of the clear but still only $5 per foot. I only need 5 feet. Would that be a better option?
    30,962
    I don't know what it is.
    Most plastics will work, I think, but you will have to observe them as I think some can turn brittle.
    Mar 2016
    Easley, SC
    407
    It looked like the flex hose that connects my booster to my PVC, only bigger. I will have to dig around and see what material it actually is.
