Results 1 to 14 of 14
Thread: PH keeps rising during my SLAM?
    Apr 2016
    Carlsbad, CA
    107
    I was over 8.2 in PH prior to my slam, so I added a gallon of MA, and it dropped to 7.2. I loaded 4 gals of CL (13.5 HDX from HD), and I was about 34 CL. Took my readings this am, and got the following:
    22 CL
    0 CC
    400 CH
    130 TA
    50 CYA
    PH 8.2 +
    2600 salt
    Per pool math, I just added 1/2 gal of MA. I'll bump my CL back up to 34 again as well (there is some mustard in the corners and stairs), but I'm pretty surprised the PH when up so much overnight. Am I missing something? Water looks nice and clear, and but for a little yellowness, the pool looks otherwise good.
    Carlsbad, CA
    17,500 gal rectangular Midnight blue Quartzscape, Pentair Intelliflo, Poolstore Vergnugen, Aquarite Salinator renovated 2016 Spring
    Feb 2015
    Chandler AZ
    1,061
    Re: PH keeps rising during my SLAM?
    pH test will read falsely high with CL above 10. If you lowered pH to 7.2 before starting your SLAM, don't bothering test it again until after your SLAM is complete and/or your CL drops below 10.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Apr 2016
    Carlsbad, CA
    107
    Ah, OK, thanks, I did not know that. So no need to add MA during the slam? I didn't do an OCLT last night, but I've obviously lost CL, so I'll try to test more today, but I"m going to bump it back up to 30 or so first.
    Carlsbad, CA
    Feb 2015
    Chandler AZ
    1,061
    No need to add MA during SLAM - as you really have no way of accurately measuring it with CL above 10. No real need to do an OCLT until the water is crystal clear, CC is 0.5 or less and your CL loss between tests gets to a low number (probably <3 CL loss between tests).
    You stated CC is 0, but didn't mention water clarity. Do your best to keep CL at SLAM levels by testing . And brush the entire pool surface 1 or 2 times a day as well.
    I'm sure you reviewed the SLAM procedure ... Pool School - SLAM - Shock Level And Maintain
    Gene
    Apr 2016
    Carlsbad, CA
    107
    Thanks, the water is clear, CC is zero, and there is some residual mustard on the steps and corners, I'll try to keep the CL at the recommended 34 and see how quickly I drop. I have a midnight blue quartzscape with abalone, so I'm a bit nervous about "bleaching" out the color by keeping the CL high for extended periods, but I want to get the H20 dialed in and keep it that way
    Carlsbad, CA
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Quote Originally Posted by jbailey895 View Post
    If there is visible algae, the water is not clear.
    22 CL
    0 CC
    400 CH
    130 TA
    50 CYA
    PH 8.2 +
    2600 salt
    If your CYA is 50, your SLAM FC level is 20ppm. Where did you get 34ppm from?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2016
    Carlsbad, CA
    107
    OK, thanks. The water itself is clear, there is just yellowing on the steps, but I guess thats attributable to the water, so I'll keep SLAMing til its gone. I got the 34 CL number from the Pool Math chart for mustard algae. I did note the difference with the SWG #'s and normal bleach #'s too. When I re-tested my CYA this morning, it was between 40-50. I realize its a subjective test, but should I try to increase my CYA level during the SLAM, or leave it for now?
    Carlsbad, CA
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Could you post a link to this chart that shows 34ppm FC for 50ppm CYA with mustard algae? When I put your numbers into pool math, I get a FC of 29ppm for mustard algae, and chem geek's data agrees:
    http://www.troublefreepool.com/threa...rine-CYA-Chart
    Also, you do not raise the FC to mustard level until after you complete a SLAM, and only for 24 hours. More here:
    https://www.troublefreepool.com/cont...-mustard-algae
    Standard shock FC level is 40% of CYA, mustard shock FC is 60% of CYA.
    Leave your CYA where it is. When we get a CYA result 'between' numbers, always round up, so your 'between 40-50' would be recorded as 50ppm.
    Dom - TFP Guide
    Apr 2016
    Carlsbad, CA
    107
    Thanks. here https://www.troublefreepool.com/calc.html is where it shows 34 CL for mustard algae, but I think thats just the generic info inserted? I know its lower with the SLAM link.
    Ok, so after adding the gal. of CL this am, I am at 30. I'll leave it and check tonight and tomorrow to see what I get, unless you think I need to lower it. Water temp is low 60
    s and my SWG is not turned on.
    Carlsbad, CA
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Pool Math shows mustard shock as 29 with a CYA of 50:
    I would let FC come down a bit & maintain FC at 20-22ppm. Once you finish the SLAM, raise FC to 30ppm for 24 hours only, then let it drift down to target levels.
    Dom - TFP Guide
    Apr 2016
    Carlsbad, CA
    107
    OK, my CL dropped to 22 again (?), and I had just some pink clouding, so 1 drop of reagent gave me .5 CC. 130 TA and holding. Is it usual to see that much of a drop in CL overnight, without a lot of organic matter in the pool? The visible mustard is almost completely gone, and i'll give it another good brushing before work, but in a way I'm relieved my CL came down, as I was concerned it would "bleach out" my midnight quartzscapes. I will likely increase the CYA after the slam to try to maintain my CL better. Thanks for the input,
    Joel
    Carlsbad, CA
    30,962
    Don't worry about bleaching anything. These numbers have been well thought out over a long number of years and they are perfectly safe. Focus on your FC and keep it right until your SLAM is complete
    Apr 2016
    Carlsbad, CA
    107
    OK, thanks, had 22 FC and 0 CC today, I think I'm outta the woods, no visible mustard anymore either, I'll keep an eye on but expect to let the FC drift down now. . .
    Carlsbad, CA
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Have you passed the OCLT?
    Dom - TFP Guide
