Thread: Aqualuminator Fountain Attachment
    Apr 2016
    Laurel, Mississippi
    73
    I am looking at purchasing a fountain for my pool and have the Aqualuminator return. Looks like one of my options is the Aqualuminator fountain. I was wondering if anyone has this fountain and could clarify something for me? Currently my water flow is pointing at a 45 degree angle toward the bottom of the pool and I notice with this attachment you have to point the flow up. I also see in the instructions that it has a bypass valve. I am curious if I have to remove the attachment when I am not using it to point my flow back the original way or can I just use the bypass valve and just turn my flow back with the attachment still attached? Thanks!
    24'x52" Quest Round AGP
    23" Hayward Sand Filter S230T, 1.5HP Matrix Pump
    Pool Rover Jr.
    TF-100 Test Kit
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    422
    Re: Aqualuminator Fountain Attachment
    Looks like it has to point up to work. and you'll have to take it off to have water flow back into the pool. The bypass is on the front and looks like it just allows water to spill out to cut back distance. I took a look at the install instructions on pentairs site.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Apr 2016
    Laurel, Mississippi
    73
    Yea I looked over the instructions and they weren't very clear on it. I read a review that said when they aren't using they just use the bypass valve but that is all that was said on the review. So it seems like maybe the bypass valve could work to direct flow back through the original flow but was trying to get some clarification by someone who may have it installed. Thanks!
    Pool Rover Jr.
    TF-100 Test Kit
    Apr 2016
    Laurel, Mississippi
    73
    Guess I may have to just bite the bullet and found out myself lol. Not a big deal since it is only around 35 bucks.
    Pool Rover Jr.
    TF-100 Test Kit
