Thread: Just filled pool
    Jul 2015
    Bentonville, AR
    2
    Just filled pool
    Just had new vinyl liner installed and in process of filling pool. Are there any suggestions on what chemicals to use during startup.
    Thanks
    37,000 In Ground
    Sand Filter
    1.5 HP pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Just filled pool
    Congrats! No, nothing special for vinyl. Plaster is the thing that needs start up procedures to be followed. Just follow the usual TFP guidelines.
    ABCs of Pool Water Chemistry
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Welcome!
    You'll need Chlorine, and Cyanuric Acid (Cya/Stabilizer/Conditioner) for sure, but maybe others. We can't say for sure without some test results so do you have any testing supplies?
    The place to get started that's essential to good pool care is Pool School. Start in the ABCs section, study the other areas, and ask questions on the forum as they arise. Knowledge and testing are the foundation, and there will be many here to help all the way. You can find this info by clicking the links in my signature. Let us know, and we can get you started. Glad you joined us, and hope you enjoy your stay.
    Essential Links:
