Thread: Hey Guys and Gals
    derek533's Avatar
    Mar 2017
    Edmond, OK
    15
    Hey Guys and Gals
    Owned a home with a pool for four years and I'm sick and tired of being a slave to the pool store. Thus, the reason I'm here! I hope to gain great knowledge from all of you and look forward to not having to throw money away on needless pucks of chlorine and shock.
    Just getting my pool up and running from a green swamp this last winter. So far, I've managed to get the green out, kill all the algae, and now I'm on to removing all the dirt and dead algae from the bottom. My Taylor K2006 kit is on the way so I'll have some numbers up for you guys here in a few days.
    As of right now with just my 5 way kit, here's my numbers:
    FC: >5.0
    PH: 7.2
    TA: 110
    From the pool store:
    CYA: 90
    I'm looking forward to being able to keep track of my own CYA and other numbers.
    Chemically, my pool seems to be ok, although my CYA is higher than I want it.
    I look forward to speaking with you all. Cheers from OKC.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Re: Hey Guys and Gals
    Welcome to TFP!!
    If your CYA is actually 90 then you have too little chlorine in the water. The absolute minimum should be 7, with you targeting 10 - 11 to keep it above the 7 floor. Pool School - Chlorine / CYA Chart
    Your first assignment when you get the K-2006 will be to test the CYA.
    Secondly you will need to perform an Overnight Chlorine Loss Test to verify that all the algae is dead.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    May 2011
    lebanon tn
    370
    Welcome. What Tim said is dead on. You need to maintain fc higher with cya that high
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Yup- bring us back all your test results when you get your spiffy new kit
    Type them out like this (easier for us to digest):
    FC
    CC
    pH
    TA
    CH
    CYA
    Then we can help you determine what needs to be done.
    Have you read this?-->ABCs of Pool Water Chemistry and other helpful articles in PoolSchool?
    How did you "kill" all your algae and the green monster? What chemicals did you use?
    Can you add a signature line to the bottom with your equipment and pool specs on it? Thanks
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
