Results 1 to 13 of 13
Thread: CuLator bag is stuck in my pipes.
    amandamugnstik's Avatar
    May 2016
    St. Cloud, Florida
    5
    After successfully treating my pool for stains, I started using the CuLator bag in my pump basket. The pool has been cloudy for two to three days so we are treating it accordingly. Well, tonight the pump sounded off and the skimmer wasn't pulling in as much as normal. When I turned the pump off I noticed the CuLator was not in the pump basket and the valve was not completely on skimmer. My husband and I couldn't get the handle all the way to skimmer and we couldn't find the CuLator. Once we turned the pump back on the CuLator reappeared and we could turn the handle all the way to skimmer. Turned the pump off and it was gone again! How am I supposed to get it out? Any help is really appreciated! Thank you!
    Here is my newbie info.: Approx. 16k gal. IG Diamond Bright Finish Exposed Aggregate Volleyball Pool, Hayward Pro-Grid DE2420, Hayward SP2310X15 Max-Flo XL 1.5 HP Single Speed Pump. Kreepy Krauly Kruiser vacuum. No heat source other than the Florida sun, which shines on it most of the day.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: CuLator bag is stuck in my pipes.
    Welcome to TFP!
    So, the water draining back to the pool is pulling the bag into the plumbing. I would remove the thumbscrew on the valve and turn it so that the handle is pointed to the pump. This will shut off the water flow to the pump. So, if one person can turn the valve and one person can immediately shut off the pump that would be best so the pump doesn't spend much time on with no water flow.
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Quote Originally Posted by amandamugnstik View Post
    Welcome to TFP!
    As pooldv has mentioned, this is a two person job.
    As a note moving forward, it's best not to put anything in the pump strainer basket. Why did you not put the CuLator into the skimmer?
    Also, why are you using the CuLator? Are you battling metals in the water?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    St. Cloud, Florida
    5
    The owner of the pool store suggested putting it in the pump basket.
    We had really bad staining, which I was able to remove. The CuLator was recommended to help prevent future staining.
    Also, THANK YOU!! I will have my husband help me with this ASAP.
    May 2016
    St. Cloud, Florida
    5
    IMG_20170327_070106.jpg I included a photo of our set up. Turning the handle towards the pump allows both our skimmer and vacuum to work at the same time. We couldn't get the handle to turn the opposite direction, even after loosening the screw. We didn't want to use too much force either. I am going to go back to the pool store today to see if they can resolve the issue. This wasn't happening prior to this weekend because I remember taking the CuLator out to clean the pump basket just last week.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    If the bag is really stuck in that diverter valve and you can't rotate the handle you can always try taking the screws out and pulling the top of the valve off. That should allow you to pull anything out that is stuck. You may want an o-ring kit on hand to replaces the seals in the valve body just in case one gets damaged. Your PB should have those handy but they also never should have told you to place that bag in the pump basket, but that's just my opinion.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    DFW, TX
    24,974
    You need to remove the thumbscrew and lift the handle slightly so it can move past the stop.
    May 2016
    St. Cloud, Florida
    5
    Thank you all for your speedy responses. When my husband got home from work we went to get it out and got lucky, it stayed in when we took the lid off. My husband doesn't want it anywhere near our pool!
    30,954
    I am so glad you got it out without harm.
    I am curious what type of staining you had and what you used to remove it.
    I have never liked anything about the culatore.......one more reason to stay away from it!
    May 2016
    St. Cloud, Florida
    5
    Hi Dave, we did a stain identification kit by Suncoast Chemicals. It led us to using their Iron & Cobalt Stain Remover and then something called Super Metal Control. The treatment worked really well! We were super impressed!
    Aug 2016
    Riverside, CA
    378
    Our steps have similar staining. Where do I get said kit?
    30,954
    Yeah, that looks like iron staining. I am glad it worked so well. Are you filling from a well? If so, that iron staining will likely occur again but you know how to get it out so you are in good shape.
    I would not use a CUlator. I think the Super Metal Control is a sequestrant and you will need to add it from time to time as it wears out. Keep an eye on it.
    Nice Work!
    DFW, TX
    24,974
    CULator removes copper, so no reason to use it for iron. Its iron removal capability is questionable and not published that I am aware of.
    Sammy2, see this link.
    Pool School - Pool Stains
