Results 1 to 14 of 14
Thread: Is my SWG going bad?
    Jun 2016
    San Diego, CA
    31
    Hello all,
    I have a Pentair salt water chlorine generator IC40, and sometimes the cell light is on and sometimes it's off.
    Is that normal?
    Salt water 28,000 Gal Pool with 1,200 Gal Spa
    Satin Matrix Pebble surface
    Pentair Intellichlor Salt Chlorinating system, Pentair Intellifo Variable Speed Pump
    Pentair 400,000 BTU heater, Dolphin DX5S Robotic pool cleaner
    750 sq foot Solar Pool Heating, Rock Grotto with waterfall
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,249
    Re: Is my SWG going bad?
    D,
    Yes completely normal.. Your cell is set to 60% so it will be on only 60% of the time. That is how they work.
    The SWCG does not change the amount of chlorine it generates, it just changes the amount of time it generates chlorine.
    Thanks for posting,
    Jun 2016
    San Diego, CA
    31
    Quote Originally Posted by Jimrahbe View Post
    D,
    Thanks for posting,
    Thank you so much Jim for clarifying that.
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    214
    Not to hijack the thread but my control unit for the SWG keeps going to checking cell. This suspends the SWG unit and my on demand acid. When I power off everything it comes back normal but hours later back to checking cell status. Any thoughts?
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    Jun 2016
    San Diego, CA
    31
    When was the last time you cleaned the cell?
    Maybe there are calcium deposits on it.
    May 2016
    Katy, Texas
    214
    Quote Originally Posted by drimran View Post
    Cleaned the cell 2 months ago. No calcium present.
    May 2016
    Katy, Texas
    214
    Hi All,
    My SWG went from being stuck on checking cell to now saying its low on salt (when I know its not). Hasn't produced chlorine in days. This is leading me to believe this thing is faulty. Anyone else think the same?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    What is the actual salt level? And what test are you using?
    May 2016
    Katy, Texas
    214
    Quote Originally Posted by pooldv View Post
    Salt level is 3400 -3500 (salt strips). Salt cell said 3500 a week ago, 3700 2 days ago, now says its low. Thing is acting wonky.
    DFW, TX
    24,974
    That should be plenty of salt. How old is the cell?
    May 2016
    Katy, Texas
    214
    9 months old.
    DFW, TX
    24,974
    Oh, heck, call your PB and ask them to warranty it.
    Jul 2016
    Central pa
    6
    Im not sure if you are dealing with the same "issues" I thought I had with my IC40, but it was reading levels all over the place until my pool water reached 61 degrees. my unit is only 9 months old as well and I thought it went bad already. although the manual states 55 degrees (or something close to that) after doing extensive research and talking with people, it seems the unit doesn't want to work properly until the water temps are above 60. I guess the manufacture also calibrates the until to read accurate salt levels at 77 degrees as well, so you either have to compensate for the values given at the current temps or buy a drop test kit to measure accurate readings of salt levels.
    16x32 IG SWG 18,000 gallons
    Vinyl Liner
    Pentair intelliflo variable speed 3HP
    Pentair Water IntelliChlor
    Pentair Sand Dollar sand filter SD-80
    Apr 2015
    Waikoloa Hawaii
    13
    Pentair had an issue with a bunch of bad flow/temp sensors a while back. If your water temp is high enough, I'd say get them to warranty replacement. The sensor is easily replaceable if you can't get it covered under the warranty
