Results 1 to 8 of 8
Thread: My current water numbers
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Hello Folks
    Received my new TFT 100 replacement chemicals.
    My numbers are the following:
    PH - 7.5
    FC - 3.5
    CC - 0
    TA - 100
    CH - 150
    CYA - 0
    Temp 87 degrees
    I am concerned about my CYA, should I be?
    Thanks in advance for the help.
    Joe
    Indoor Endless Pool (IG). Aug 2012, 5200 Gal. Vinyl, Pleatco PWW10-M filters, Gecko controller, Laing pump, TFT 100
    Jan 2012
    'burbs of Augusta, Georgia
    8,591
    Re: My current water numbers
    Well, if you don't want your FC to overpower you in that indoor pool, yeah, you need some CYA.
    I'd suggest about 30ppm (no more) to help buffer the chlorine. FC/CYA Chart
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Thanks, so I am sorry, what do I add to the pool to achieve you recommendations?
    I am assuming some sort of stabilizer, do you have any recommendations? All I use in my pool is bleach.
    thanks
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    I found this:
    Instant Pool Water Conditioner | Backyard Water Care | Natural Chemistry
    Need only a half of gallon to raise my CYA to 30
    Thanks so much for your help
    Joe
    Jan 2012
    8,591
    Yup, you found the right product, Joe. You could also find it in cheaper granular form but to tell you the truth I'm kinda over that and have been using the liquid lately.
    Yippee
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Thanks Yippee...
    joe
    ngc4900's Avatar
    Sep 2012
    Fredericksburg, VA
    56
    Yippie: I read this on this site: " CYA - Cyanuric Acid - Protects chlorine from sunlight and determines the required FC level. (outdoors 30 to 50, SWG 70 to 80, indoors 0 to 20)" Since I have an indoor 5000Gal endless pool, which is covered 98% if the time, should I shoot for 20? The FC at 3.0 does not overpower me. I will probably add a little to see where it ends up. As an ER doc, I have learned it is easier to ad a little than to give to much......
    Thanks
    again
    Joe
    Jan 2012
    8,591
    The only reason we suggest 30 is that 20 is very hard to detect on the test tube. If you're comfortable with that I'd say go for it.
    Yippee
