Thread: Stuck in Deep End
    Mar 2017
    Camarillo
    3
    Stuck in Deep End
    Hi all, first post!
    I inherited an original "The Pool Cleaner" (4x model) when I bought my house. It was great but with age the wheels started to disintegrate and needed to be replaced. Hayward now owns the product and offer two options for wheels: regular and tile. I've tried both, alas my Pool Cleaner can't get enough traction to escape the deep end equipped with either. My pool has glass beads which no doubt must be tricky for pool cleaners.
    The original wheels were not at all like the new rubber ones. They appeared to be made of some kind of high density foam with a special tread glued on. I can't find them anywhere.
    I've tried adjusting suction, no luck. I've tried adding weight to the vacuum to increase grip, no luck. Any ideas from the community would be much appreciated.
    Thanks!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    Re: Stuck in Deep End
    Welcome to TFP! Good to have you here
    I have no experience with the wheels for hayward/poolverneugen, but sometimes two changes occur which seem unrelated, or another change might be helpful. If there's a return jet pushing the hose too hard, away from where you want it to go, it can make it more difficult for a suction cleaner to get around. Just something I could think of! Good luck with it. Sounds like you've already tried more suction, which would be my instinct as well.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mar 2017
    Camarillo
    3
    Thanks for the reply needsajet! I notice you have glass beads too... what kind of pool cleaner do you use?
    Trevor | Pool stats: in-ground 16 x 34 rectangular, 25,000 gallons, beadcrete (glass pebbles), 4x 1.5 HP polaris pumps (pool, waterfall, waterslide, spa jets), DE Filter, (disabled)polaris salt cell, thermal solar collectors on roof, retractable cover.
    needsajet's Avatar
    Jan 2016
    4,493
    If you're in the USA, mine is called the Pentair (Kreepy Krauly) Warrior
    Pentair Kreepy Krauly Warrior Review - YouTube
