Thread: When to add chemicals after resurfacing?
    Feb 2017
    Tampa
    25
    Hello
    We just completed resurfacing (pebble-tec) on 3/7 and are planning on installing a SWG that we recently purchased, CircuPool SJ Series 40,000 gallon.
    I believe the pool company did an Acid Start up and we are taking over the maintenance next week.. We are no longer going to be using a pool cleaning service and will be testing ourselves but also require monthly testing for our pool warranty.
    We were told we can use our pool now? But we have some concerns as there is no chlorine.
    FAC = 0
    TAC = 0
    Salt = 0
    CH = 180
    CYA = 40
    TA = 40
    PH = 7.2
    Phosphates = 500
    We are waiting 30 days to add salt and install the SWG but should we add bleach and the other items recommended by the TFP pool calculator during the first 30 days? Also, should we add the chemicals in any specific order? I see the time frames for adding and retesting but was wondering if there is a preferred order?
    Also, we have a pool warranty that requires monthly testing by a commercial water chemical retailer and the following levels:
    I have seen other posters on TFP with these numbers so we are going to try to stay closet these if possible.
    CL = 1-3
    PH 7.2 7.6
    TA = 80-120
    CH 200-400
    CYA = 30-50
    Sequest 12 ppm
    Salt Level 2500-3500
    Tom
    40x24 round/kidney shaped, IG 28k gal, Built in 82, 2017 Resurfaced pebble tec. Hayward DE Filter DE2420 1.5hp, Hayward SP0710XR50 Vari-Flo Pool Valve, marathon motor 1.00 HP, 1.50 SF, 1.50 THP, Circupool SJ Series 40,000 and Dolphin nautilus pool cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: When to add chemicals after resurfacing?
    Pebbletec has start up instructions here
    Pool Care Instructions Pebble Tec
    And they will send you more detailed start up instructions for your pool after you register your warranty here,
    Product Registration Pebble Tec
    TFP's recommendation for a saltwater pool are here,
    Pool School - Water Balance for SWGs
    The most important thing right now is to manage your pH, keep it between 7.6 and 7.8 would be my recommendation. And TA between 60 and 80.
    It is important to maintain chlorine levels above minimum for your CYA level at all times to keep the pool safe, sanitized and algae free. FC/CYA Chart, bleach or liquid chlorine is an excellent way to do that. You can also use trichlor pucks to chlorinate u til your cya gets up to the level you want it. Which I would recommend to be 80 ppm for your location.
    Here is a good basic intro to water chemistry. ABCs of Pool Water Chemistry
