Thread: Clear?
    Jun 2015
    Houston, Tx
    19
    Clear?
    This is my third SLAM I have done, but things are a little different this time. In the past I always had a CC reading that went to zero just about he same time the water looked clear. This time my CC has always been zero (even though the water was definitely NOT clear to begin with). Throughout the SLAM my water has been getting more clear but the CC has remained at zero. Since I don't have an objective CC reading that will go to zero when I am done I am having a hard time knowing when my SLAM is over. I keep on asking myself, "is the water really 100% clear?". Any advise would be appreciated. Thanks.
    In ground 30,000 gallon rectangular plaster/pebble pool, hot tub with blower, 2 HP Pentair WisperFlo Single Speed Pump, 420 Pentair Clean and Clear Plus Cartridge Filter, Pentair Rainbow 320 Chlorinator, Easy Touch Control System, Pentair 400K BTU heater, Interfab G Force Slide with dedicated 1 HP pump, Travertine Decking, CoverStar automatic pool cover
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    Re: Clear?
    SLAMs can be different in the way that they manifest themselves. But......
    If your water is not clear then you keep the SLAM up. Remember you have completed the SLAM when you meet all 3 conditions
    1.) Water is clear
    2.) OCLT is 1.0 FC or less
    3.) CC of 0.5 or less.
    Not quite sure what you mean by an objective CC reading that will go to 0.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Re: Clear?
    Quote Originally Posted by BlueCoug View Post
    Clear means that there is not one speck of algae, dead or alive. Clear means I can tell heads or tails on a quarter at the bottom of the deep end. Clear is when I can turn the pool light on and it doesn't look like a snow storm.
    You haven't mentioned passing the OCLT. That is also required to complete the SLAM.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
