Thread: Aqualink control panel problem
    Mar 2017
    Houston/Texas
    1
    Somehow tripped the breakers replacing an actuator. Breakers are reset, but no power to the control panel
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Aqualink control panel problem
    Welcome to TFP!
    One of the sparkies will be along to help you on this. You probably don't want my electrical advice.
    Essential Links:
    ps0303's Avatar
    Jul 2011
    FL
    3,919
    I believe there is a fuse on the main control board. Open your main control box outside, remove the screws from the cover and you should see the board. The fuse is on the back. You can also check to make sure you have power to and from the transformer
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
