Thread: Am I crazy to try a used aquabot turbo?
    Oct 2010
    Eastern TN
    174
    I have a Polaris 9300xi that is having trouble with getting stuck on my pool steps. I found a used aquabot for under $400 with a 30 day warranty. Am I crazy to consider a robot w/o warranty or would it be worth giving the aquabot a try?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Am I crazy to try a used aquabot turbo?
    Sorry, I don't know those or their prices, but Robots are the way to go. Wouldn't want to be without mine.
    Essential Links:
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Digit,
    I have bought four used robots from Craig's list. Two were sold to me in "working" condition, and two were sold for "parts".
    All of them were old as dirt Dolphin Diagnostics...
    One has been working for the past four years in a rent house pool.
    One worked for about two years and I repaired it using the extra parts.
    One that I bought for "parts" just had a bad power supply and is still working today at another rent house.
    I guess my point is that it is always a risk when buying used items and there is no way to know for sure what you are going to get.
    But, if the seller will give you a 30 day warranty, it might be worth the risk. Although it seems to me $400 is a lot of money for a used $600 to $800 machine.
    All that said... Once your go Robot, you'll never go back...
    Thanks for posting,
    Oct 2010
    Eastern TN
    174
    I couldn't find much searching for reports on the aquabot classic turbo. Hopefully someone can comment. It seems like most robots have a relatively short lifespan compared to price.
    Oct 2007
    Parkland, FL
    753
    I would not buy a used robot unless you can get some type of extended warranty which usually you can't with used products. The motors themselves are 250+, power supply is 200 etc. One failure and its not uncommon and you will be throwing the robot away. For 600 you can get a smartpool with 2 year warranty. You can also sometimes find refurbs and open boxes cheap on ebay that will allow purchasing an extended warranty.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
