Thread: CYA level salt pool
    Jun 2015
    Rocklin Ca
    79
    CYA level salt pool
    I have a salt water pool I'm bring up the CYA level last couple of days right around 30 now. The SWG hasn't worked in about 3 years, new cell new circuit board I'm just done with it. But I do put salt in the pool try to keep it around 3200 I asked this once before but want to confirm the answer what level of CYA do I use on the chart with bleach 30-70 or with SWG 70-80. Thanks.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    30,944
    Re: CYA level salt pool
    Use the 30-70 model for manually chlorinated pools. A CYA of around 40-50 would be ideal for your climate in Rocklin and should result in an FC loss of about 2 ppm daily if you keep the FC around 5 ppm or so.
    There is no real purpose in having your salt level @ 3200 without the SWG. I would let it drift down to about 2000 personally but there is little harm keeping it where you are.
    Jun 2015
    Rocklin Ca
    79
    Thanks I shooting for around 40 I'll go 45. I'll try the salt level at 2000 I haven't even checked it yet with all the rain I'm sure it's really low. BTW everything else is looking good the pool numbers I take care care of it year round.
