Thread: Distance from gas heater to pool water matter?
    Exton, PA
    250
    I'm going to work with the town to get permits for a NG heater. I'm thinking of placing the heater, along side my HVAC, but that's about 50' to the current pump/filter. The pump/filter are 5 feet from the pool's edge.
    - Can I put the units 50 apart, without issue?
    - If I place them that far apart, do I need to upgrade the HP for my pump?
    Any other issues/concerns?
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Re: Distance from gas heater to filter/pump matter?
    50' is pretty far and I wouldn't do it. You can't get it closer? Also, you need to make sure that putting it so close to an AC unit is within code.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    50' of horizontal 2" plumbing isn't really that big of a deal and should not require a pump upgrade. I would be more concerned about the heat loss through the plumbing while traveling that distance.
    Exton, PA
    250
    Quote Originally Posted by pooldv View Post
    Yep. The heat loss was my concern. If you picture my pump at 4:00 on the pool, I believe I'll be permitted to put the heater at 10:00, so about 25 feet. I was just reading on here that folks put them with their AC unit. And, my AC is against a wall with no windows. Perhaps the best selling point is that I believe I could run the entire gas pipe along the basement ceiling and just pop out where the AC unit is, so that saves a lot of digging $$$.
