Thread: Pool opening issue
    Jul 2015
    Atlanta, GA
    13
    Pool opening issue
    I set out to open our pool today. I usually pay the pool company to do it but after watching them and YouTube, I figured I could to this and save some money. I followed the TPF pages and have completed the following:
    - Cover removed
    - Plugs and gizmos removed, replaced with fittings
    - Skimmers w/ hair nets replaced to catch the lovely pollen in GA
    - Plugs replaced in pumps and filled with water
    - Electrical returned to 'on'
    I might be missed some in the list but the main pump just makes a 'buzzing' noise when I turn it on. A second pump that runs a water feature is functioning as expected.
    I found another TFP thread about buzzing pumps and it talked about capacitors and this is a tad over my head but I followed the instructions here ... pool pump makes humming noise and does not pump ... but no clue if what i was doing was correct. But whatever I touched when I took out the pump basket, didn't move.
    Its a Hayward Super Pump SP1610z1m and I don't see a capacitor in a diagram I found that looks at least similar to what we have. Hayward Super Pump SP-1600 Series pool pump parts, Discount parts for Hayward Super Pump SP-1600 Series
    Does anyone have any other suggestions before I resort to calling the pool company?
    Thanks in advance for any help!
    Atlanta, GA, 5-year old 25,000'ish gallon SWG In-Ground Gunite Pool (we've owned since 2013 and couldn't have made it so far without TFP!), AquaPlus PL, T-13 Salt Cell replaced 7/13
    TF-100, K-1766, Maytronics Dolphin M5
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    Re: Pool opening issue
    Are your valves all open? Is there water in the pump?
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jul 2015
    Atlanta, GA
    13
    Valves are open, pump has water
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Good for you. No reason to pay them if you can do it. By a nice bottle of Wine, or some other refreshing Beverage with the savings.
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    I know this will sound funny, but take a mallet and GENTLY tap around the motor area (the metal area not the wet side) as soon as you turn it on. Could be from corrosion in the motor. See the attached video for a few easy tips including that one. But please don't put your hand in pump with the circuit breaker flipped on!
    https://www.youtube.com/watch?v=y9XqVorA09U
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
