Thread: Jandy LED Lights, stop it from flashing?
    Mar 2017
    Cedar Creek, TX
    4
    Hi,
    Is there anyway to have the Jandy LED lights just stay on the color and not flash. The flashing is getting a little old!
    Didn't see anything in their manual.
    Thanks
    Jun 2014
    17,347
    Re: Jandy LED Lights, stop it from flashing?
    Not sure if this will work compared to my type of LEDs, but if I toggle the light switch (quickly) off then back on at the color I want, they remain on that color. If your lights operate differently, hopefully another Jandy member will reply soon. Welcome to TFP!
    Mar 2017
    Cedar Creek, TX
    4
    Thank you!
    I can get it to stay on one color. But if flashes off and on on that color. However, I will try the toggle quickly to see if I can stop the flashing and get it more soothing!
    Surely the light is able to do this.
    Thanks
    Mar 2017
    Cedar Creek, TX
    4
    Didn't seem to work. Cannot get it to not flash. Wondering if this behavior is not normal, perhaps water is on the LED panel causing weirdness?
    It is flashing blue (or whatever color I put it on) like a strobe light. Even the ones that change color do so in a flash instead of a smooth transition.
    Any Jandy owners out there? I can call there support line when they are open, plan to!
    Thanks
