Thread: Peeling Grout
    Mar 2017
    Key West, Florida
    6
    Peeling Grout
    Dear TFP Community,
    We drained and refilled our 5000 gal., tiled pool last night. Four years ago we had the pool Re-grouted. The reason we drained the pool was because our CYA was off the charts.
    After refilling, we discovered "grid sections" of grout peeling off sections of the pool tiles.
    We are speculating that the chemistry imbalance brought on by the high CYA may have caused the grout deterioration.
    Has anyone had a similar problem? Am I overlooking another possible cause?
    Thank you.
    Ron (H2o) Burd
    triptyx's Avatar
    Apr 2016
    1,476
    Re: Peeling Grout
    I don't believe CYA by itself would have caused that issue. I would be far more inclined to suspect it was a result of a protracted pH imbalance, or a CSI that was too acidic for too long.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Peeling Grout
    Welcome to TFP, and sorry to hear of your troubles!!
    I think it's something else, and my first guess would be low pH and TA over time. Do you have any test records, or recent test results? Without those its only a guess, but Cya isn't the cause of grout loss.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Peeling Grout
    Hey Ron,
    I've just had a look at some of your recent threads the last several days, and sorry I have missed them, so I want to clarify what I said above. The products you've been using that contain the stabilizer are acidic and very good at lowering the pH and Alkalinity. Even though the Stabilizer (Cya) is a product called Cyanuric acid the high level of it alone did not cause your pH to drop.
    I know it's confusing, but we could get your Cya up to a very high level and it not create a low and lasting pH situation. Over time, the products like pucks/tablets/powders that deliver Chlorine and Cya contain compounds that will however. A steady extended diet of these products have likely driven your pH quite low for some time now, and just guessing this is likely the situation.
    Test result if any exist, I think would bear this out.
    Essential Links:
