Thread: Underwater lubricant
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    I am looking for something that I can put on my return eye that will make it swivel a little easier. It is very hard to move. I was thinking of taking it off and putting some type of lubricant on it but did not know what would be the best type.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Underwater lubricant
    Use oring lubricant.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    They make silicone based lubes for things like pool pump seals and such. That should be easy to find and do the job.
    Essential Links:
    chayne's Avatar
    May 2016
    419
    i sure appreciate the info.
    Charles
    Coleman 16'x48"
