Results 1 to 8 of 8
Thread: CYA Might be High
    Mar 2016
    Fort Worth tx
    16
    CYA Might be High
    Pool is less than a year old and have always used liquid chloring and only tablets when on vacation. What else can cause the CYA to rise, if my test was accurate? I ran out of the CYA reagent, so I am ordering more. Not even sure what the actual measurement was since it was below the 100 mark.
    Test Results today:
    FC 4.5
    CC 0
    PH 7.6
    TA 75
    CH 300
    CYA Halfway from the bottom and 100 on the K2006 test and black dot is gone.
    June 2016, 32x16 IG, approx 16k gallons, Plaster, DE, Jandy dev60 filter, Jandy 2 speed pump and Taylor K2006 test kit.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: CYA Might be High
    Any powdered/solid type chlorine can contribute. Depending on how many tablets you used, it can take a short time to get into trouble.
    Also. there is always the chance that it was just simple testing error.
    I was at Walmart the other day and noticed that they had the 6-way test kit that includes CYA. In a pinch that might work for you.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    There are other forms of solid that don't contribute Cya, those being Cal-Hypo, and Lithium bound Chlorine but the latter is far less commonly used due to cost. Still pabeader is right that other bags, boxes and such are the likely culprits.
    Your Cya test was accurate, or likely close enough that it doesn't matter. Cya can build much quicker than most people imagine so don't doubt it too much as it wouldn't be surprising.
    Essential Links:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,728
    It is best to make sure the pump has been running 15-30 minutes before pulling your test sample. There is some debate if water temperature affects the test result, so you may want to let the sample warm up to a least 70 degrees to help with accuracy. Also make sure you read the result in bright sunlight with the sun at your back if possible.
    Love TFP? Become a
    TFP Supporter!
    30,946
    how long has it been since you have tested CYA prior to this test?
    Mar 2016
    Fort Worth tx
    16
    Last test was end of summer, water temp is below 70. I have only used tablets twice since pool was built. Nothing other than bleach or liquid chlorine and acid have been used in pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    That doesn't seem to match your Cya results unless I misunderstood you. Let's see what you get after you run a new one when you are re-supplied.
    Essential Links:
    30,946
    Yeah, let's start fresh with a complete test so we can help without guessing.
