Thread: AutoPilot- Pool Pilot Digital DIG-220 - Please Help
    Mar 2017
    palm coast, FL
    3
    Good Morning,
    I am new to this forum but I will try to include all information. I have had the Auto Pilot, Pool Pilot Digital DIG-220 for about 8 years. In 2014 I installed a new cell SC-36 (RD35/22). Yesterday I noticed that the pool had some algae so I went to check to make sure that the little tabs on the timer did not fall off again. The little tabs were firmly in place so I turned the system on and ran a "test". The test said that the salt was at 1600 and to add 116 pounds. I only had 2 40 pound bags on hand so I put both bags into the pool. After 30 minutes I performed another "test" and it still said that salt was at 1600. That was my first warning sign because usually after putting salt into the pool the number jumps. I let the system run all night and this morning the test still said 1600. I pushed the boost mode and after a few minutes it jump to 2700. So hopefully for now I am producing chlorine. I have not had a problem like that and not sure if the control panel is going to if maybe a new cell is needed, but last time a new cell was needed the control panel said "check cell". I am hoping for some insight
    Pool Information:
    Small pool - only about 12,000 gallons
    Hardness - normal
    Total Chlorine - Very low
    Free Chlorine - Low
    PH - normal
    Stabilizer - low
    Control Panel Information - After Boost mode
    Warning - Purifier Off Check flow
    Cell SC-36 (RC35/22)
    Salt 2700
    0v 5.0A
    Power Level 1
    Any help would be greatly appreciated. Thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: AutoPilot- Pool Pilot Digital DIG-220 - Please Help
    Welcome to TFP!
    I don't know about your equipment, but if you are seeing Algae, we will recommend getting rid of it with our shocking procedure we call a SLAM. Its a process of keeping the Chlorine high until the pool is completely clear of all living and dead Algae. You wont be able to to do that with the SWG alone, as it simply isn't designed for that purpose.
    Do you have any testing supplies, particularly for salt? You might want to test the salt levels with an actual test to be sure of your Salt levels before making more additions. Additionally, you will need a proper kit for the procedure I suggested, and you can see links in my signature for most of the info I mentioned here. If you can test, a complete set of numbers would be very helpful to give you the proper advice.
    Essential Links:
    Mar 2017
    palm coast, FL
    3
    I just got back from pinch a penny and the salt level is actually 3400.
