Results 1 to 7 of 7
Thread: Brand new Coleman salt water pool
    Sep 2016
    Kunkletown,Pa
    80
    Will be putting it up soon 26 round 52 high. I am on well water with a filter system using calcite. I was thinking of using the well with like one load of delivered balanced water about 4-5k gal . To make it least some chemical right away. And a little easier on my well pump. And a little quicker to fill pool. Should I do this or take about 4 days to fill pool? Or any other suggestions. Thanks
    15K Gal coleman 26 Round Intex swg Hayward S210T93S 1 1/2 hp matrix pump 21 inch sand filter Taylor k2006
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Brand new Coleman salt water pool
    I'm not sure I understand everything here. The well filter system you say is Calcite? What is that for? When you say make chemical right away, not sure what you mean.
    Sorry for all the questions, but I want to understand.
    Essential Links:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,724
    Do you know if your well water has iron in it? If it does it will be much easier on you if you can fill the pool with iron free water. If you are not sure about iron content before you fill the pool get a 5 gallon bucket of well water and mix in about a 1/2 cup of bleach. If the water has high levels of iron the water will turn a muddy brown color.
    Love TFP? Become a
    TFP Supporter!
    Sep 2016
    Kunkletown,Pa
    80
    Calcite is an iron filtration media . If I use my well to fill pool want to do it slow . I just had a new well pump done. The old one was a builders special. According to the pump service I used .this one is a big improvement in pressure and now I can't see sediment. Zea3 thanks for the tip will try this weekend. I am concerned on taking too long to fill pool won't it bacteria or other problems?
    Sep 2016
    Kunkletown,Pa
    80
    Ok the bleach test . the water stayed clear. So now I know I can use the water. If I fill the pool from the well it will take a few days before the pump will be able to move the water. do I need to pour in bleach as the water is filling ,even though the water can't circulate. Or do I have a few days where the water will be ok. I did a water test out of sink faucet Ph 7.1 Ta 90. using taylor kit
    Jul 2009
    Houston, Texas
    10,724
    Drizzle the bleach in while you walk around the pool then use a pool brush or leaf net to stir the water after you add bleach.
    Love TFP? Become a
    TFP Supporter!
    Sep 2016
    Kunkletown,Pa
    80
    Great thanks Should anything else be added as pool is filling? I am thing of using a PPS6120-Side__11646.1487274814.30.30filter.png pure filter do these work to remove some metals if there are any?
