Thread: Pump dead. What now?
    Jun 2016
    Austin, TX
    335
    My pump is dead and not being replaced until Monday. So I have 3 days of having to manually chlorinate and mix the pool. So how high should I bring up my FC and do I just brush a lot? Days are getting hot here so I am worried about FC loss but my CYA is at 80 so I think I will be ok.
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Pump dead. What now?
    You'll be fine unless you are on the edge of an Algae bloom or into one already. Your water shouldn't be warm yet, but keep the FC up for at least 70 Cya (non salt pool) and you should be fine. As long as you brush, brush, brush everyday, and more if you can.
    Essential Links:
    Jun 2016
    Austin, TX
    335
    No. I'm good. Well above my target FC. It's a salt pool so my CYA is 80. Pool water is in the 70s already. So I guess I'll just bump the FC up a bit and brush. Thanks.
    Jun 2016
    Austin, TX
    335
    Pool survived! that was less stress than I thought. Pump goes in tomorrow!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Good news!
