Thread: In-ground pool cover for catching leaves - solid or mesh?
    Hi,
    I'm looking into getting a pool cover to reduce the amount of leaves that fall into my pool. Should I be thinking of mesh or solid type? And recommended styles or DIY guides?
    Thank you.
    New pool owner
    25k gal., plaster, Hayward DE6020 filter
    Mar 2016
    Easley, SC
    407
    Re: In-ground pool cover for catching leaves - solid or mesh?
    Don't go with the cheap mesh ones on amazon. Had two of them and both ripped. I have a solid winter cover and like it but it would be a pain to install and remove just for leaves.
    18x36 inground / 28k gal / Vinyl liner (replaced in 2018) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump / Stenner pump (85MHP17) w/55 gallon storage tank / Pentair heat pump HP1200 (To be installed) / TF100 Test kit
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Ive tried both and the mesh is a real pain. I now just use my solar cover and blow the leaves to one end. They won't blow off the mesh and eventually drop into the pool.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Mod Squad JohnT's Avatar
    SW Indiana
    9,333
    Are you looking for something for during the swimming season or during the winter?
