Thread: Replacing Filter Cartridges
    Jan 2010
    Spring Texas
    48
    I have a big beige brown Hayward cartridge filter it is about seven years old and still uses the original cartridges. I do not know the model of this filter and I cannot find it on the outside. How do I know which cartridges to purchase for replacement? Is measuring the only way ?
    Thank for any advice.
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Jun 2014
    17,347
    Re: Replacing Filter Cartridges
    You could measure the current filter sizes (length, diameter, etc) and compare that to replacements. Most cartridge filter web sites will list the dimensions so you can get a good match. As another long shot, you could post a pic of that brown Hayward filter housing. Maybe some folks here will recognize it to give you a model number. Also consider calling Inyopools.com as they have an extensive reference library and may be able to help as well.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I really like Pleatco cartridges, they are a lot better than my original Pentair cartridges. Pleatco has an 800 number and they can find your cartridges based on measurements. Length, internal diameter and external diameter.
    Jan 2010
    Spring Texas
    48
    Thank you tfp Mod Squad
